[PROJ] Bugs in PROJ_LIB handling?
Even Rouault even.rouault at spatialys.com
Wed Oct 5 14:06:45 PDT 2022
I don't confirm this. Your test case works fine for me with 8.1.0 and a
few later versions
$ g++ test.cpp -o mytest -I/home/even/install-proj-8.1.0/include
-L/home/even/install-proj-8.1.0/lib -lproj
$ LD_LIBRARY_PATH=/home/even/install-proj-8.1.0/lib ldd mytest | grep proj
     libproj.so.22 => /home/even/install-proj-8.1.0/lib/libproj.so.22
(0x00007f6d7f059000)
$ PROJ_LIB=/tmp/foo LD_LIBRARY_PATH=/home/even/install-proj-8.1.0/lib
./mytest
proj searchpath: /home/even/.local/share/proj:/tmp/foo
Le 05/10/2022 à 22:44, Tom O'Reilly a écrit :
> How exactly is $PROJ_LIB intended to alter the PJ_INFO.searchpath? It
> appears to behave differently between PROJ-7.1.0 and PROJ-8.1.0:
>     PROJ-7.1.0 replacesthe last element of PJ_INFO.searchpath with
>     $PROJ_LIB
>     PROJ-8.1.0 does not add the contents of $PROJ_LIB environment
>     variable to PJ_INFO.searchpath.
> (These are the only two PROJ versions I've tested so far)
> I determined this behavior from this simple program:
> #include <iostream>
> #include <proj.h>
> int main(int argc, char **argv) {
>   PJ_INFO projInfo = proj_info();
>   std::cerr << "proj searchpath: " << projInfo.searchpath << std::endl;
>   return 0;
> PROJ-7.1.0, PROJ_LIB not set:
> proj searchpath: /home/oreilly/.local/share/proj:/usr/local/share/proj
> PROJ-7.1.0, PROJ_LIB=/tmp/mystuff:
> proj searchpath: /home/oreilly/.local/share/proj:/tmp/mystuff
> PROJ-8.1.0, PROJ_LIB not set:
> PROJ-8.1.0, PROJ_LIB=/tmp/mystuff:
> Are there bugs in how PROJ_LIB is handled? What is the intended effect
> of PROJ_LIB on searchpath?
> Thanks,
> Tom
> Thomas C. O'Reilly
> Monterey Bay Aquarium Research Institute
> 7700 Sandholdt Road
> Moss Landing, California 95039-9644
> 831-775-1766 (voice)
> 831-775-1620 (FAX)
> oreilly at mbari.org (email)
> http://www.mbari.org (World-wide Web)
> "The machine does not isolate us from the great mysteries
>  of nature, but plunges us more deeply into them."
>    - ANTOINE DE SAINT-EXUPERY
>      "Wind, Sand, and Stars" (1939)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20221005/be460500/attachment-0001.htm>
More information about the PROJ mailing list
