[PROJ] Bugs in PROJ_LIB handling?
Tom O'Reilly oreilly at mbari.org
Wed Oct 5 14:20:11 PDT 2022
Hi Even,
Thanks, interesting.
The PROJ-8.1.0 exhibiting the odd behavior comes from source distributed with VTK-9.2.0. I'm assuming that version info is accurate, but I guess it might not be.
So is the PROJ-7.1.0 behavior "correct"?
Thanks,
Tom
Thomas C. O'Reilly
Monterey Bay Aquarium Research Institute
7700 Sandholdt Road
Moss Landing, California 95039-9644
831-775-1766 (voice)
831-775-1620 (FAX)
oreilly at mbari.org (email)
http://www.mbari.org (World-wide Web)
"The machine does not isolate us from the great mysteries
of nature, but plunges us more deeply into them."
- ANTOINE DE SAINT-EXUPERY
"Wind, Sand, and Stars" (1939)
From: "Even Rouault" <even.rouault at spatialys.com>
To: "Tom O'Reilly" <oreilly at mbari.org>, "proj" <proj at lists.osgeo.org>
Sent: Wednesday, October 5, 2022 2:06:45 PM
Subject: Re: [PROJ] Bugs in PROJ_LIB handling?
I don't confirm this. Your test case works fine for me with 8.1.0 and a few later versions
$ g++ test.cpp -o mytest -I/home/even/install-proj-8.1.0/include -L/home/even/install-proj-8.1.0/lib -lproj
$ LD_LIBRARY_PATH=/home/even/install-proj-8.1.0/lib ldd mytest | grep proj
libproj.so.22 => /home/even/install-proj-8.1.0/lib/libproj.so.22 (0x00007f6d7f059000)
$ PROJ_LIB=/tmp/foo LD_LIBRARY_PATH=/home/even/install-proj-8.1.0/lib ./mytest
proj searchpath: /home/even/.local/share/proj:/tmp/foo
Le 05/10/2022 à 22:44, Tom O'Reilly a écrit :
How exactly is $PROJ_LIB intended to alter the PJ_INFO.searchpath? It appears to behave differently between PROJ-7.1.0 and PROJ-8.1.0:
PROJ-7.1.0 replaces the last element of PJ_INFO.searchpath with $PROJ_LIB
PROJ-8.1.0 does not add the contents of $PROJ_LIB environment variable to PJ_INFO.searchpath.
(These are the only two PROJ versions I've tested so far)
I determined this behavior from this simple program:
#include <iostream>
#include <proj.h>
int main(int argc, char **argv) {
PJ_INFO projInfo = proj_info();
std::cerr << "proj searchpath: " << projInfo.searchpath << std::endl;
return 0;
PROJ-7.1.0, PROJ_LIB not set:
proj searchpath: /home/oreilly/.local/share/proj:/usr/local/share/proj
PROJ-7.1.0, PROJ_LIB=/tmp/mystuff:
proj searchpath: /home/oreilly/.local/share/proj:/tmp/mystuff
PROJ-8.1.0, PROJ_LIB not set:
PROJ-8.1.0, PROJ_LIB=/tmp/mystuff:
Are there bugs in how PROJ_LIB is handled? What is the intended effect of PROJ_LIB on searchpath?
Thanks,
Tom
Thomas C. O'Reilly
7700 Sandholdt Road
831-775-1620 (FAX)
[ mailto:oreilly at mbari.org | oreilly at mbari.org ] (email)
[ http://www.mbari.org/ | http://www.mbari.org ] (World-wide Web)
PROJ mailing list [ mailto:PROJ at lists.osgeo.org | PROJ at lists.osgeo.org ] [ https://lists.osgeo.org/mailman/listinfo/proj | https://lists.osgeo.org/mailman/listinfo/proj ]
-- [ http://www.spatialys.com/ | http://www.spatialys.com ] My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20221005/ae2a4568/attachment.htm>
More information about the PROJ mailing list
