[PROJ] Bugs in PROJ_LIB handling?
Even Rouault even.rouault at spatialys.com
Wed Oct 5 14:50:40 PDT 2022
> So is the PROJ-7.1.0 behavior "correct"?
yes
> Thanks,
> Tom
> Thomas C. O'Reilly
> Monterey Bay Aquarium Research Institute
> 7700 Sandholdt Road
> Moss Landing, California 95039-9644
> 831-775-1766 (voice)
> 831-775-1620 (FAX)
> oreilly at mbari.org (email)
> http://www.mbari.org (World-wide Web)
> "The machine does not isolate us from the great mysteries
>  of nature, but plunges us more deeply into them."
>    - ANTOINE DE SAINT-EXUPERY
>      "Wind, Sand, and Stars" (1939)
> *From: *"Even Rouault" <even.rouault at spatialys.com>
> *To: *"Tom O'Reilly" <oreilly at mbari.org>, "proj" <proj at lists.osgeo.org>
> *Sent: *Wednesday, October 5, 2022 2:06:45 PM
> *Subject: *Re: [PROJ] Bugs in PROJ_LIB handling?
> I don't confirm this. Your test case works fine for me with 8.1.0 and
> a few later versions
> $ g++ test.cpp -o mytest -I/home/even/install-proj-8.1.0/include
> -L/home/even/install-proj-8.1.0/lib -lproj
> $ LD_LIBRARY_PATH=/home/even/install-proj-8.1.0/lib ldd mytest | grep proj
>     libproj.so.22 => /home/even/install-proj-8.1.0/lib/libproj.so.22
> (0x00007f6d7f059000)
> $ PROJ_LIB=/tmp/foo LD_LIBRARY_PATH=/home/even/install-proj-8.1.0/lib
> ./mytest
> proj searchpath: /home/even/.local/share/proj:/tmp/foo
> Le 05/10/2022 à 22:44, Tom O'Reilly a écrit :
>     How exactly is $PROJ_LIB intended to alter the PJ_INFO.searchpath?
>     It appears to behave differently between PROJ-7.1.0 and PROJ-8.1.0:
>         PROJ-7.1.0 replaces the last element of PJ_INFO.searchpath
>         with $PROJ_LIB
>         PROJ-8.1.0 does not add the contents of $PROJ_LIB environment
>         variable to PJ_INFO.searchpath.
>     (These are the only two PROJ versions I've tested so far)
>     I determined this behavior from this simple program:
>     #include <iostream>
>     #include <proj.h>
>     int main(int argc, char **argv) {
>       PJ_INFO projInfo = proj_info();
>       std::cerr << "proj searchpath: " << projInfo.searchpath <<
>     std::endl;
>       return 0;
>     PROJ-7.1.0, PROJ_LIB not set:
>     proj searchpath: /home/oreilly/.local/share/proj:/usr/local/share/proj
>     PROJ-7.1.0, PROJ_LIB=/tmp/mystuff:
>     proj searchpath: /home/oreilly/.local/share/proj:/tmp/mystuff
>     PROJ-8.1.0, PROJ_LIB not set:
>     PROJ-8.1.0, PROJ_LIB=/tmp/mystuff:
>     Are there bugs in how PROJ_LIB is handled? What is the intended
>     effect of PROJ_LIB on searchpath?
>     Thanks,
>     Tom
>     Thomas C. O'Reilly
>     7700 Sandholdt Road
>     831-775-1620 (FAX)
>     _______________________________________________
>     PROJ mailing list
>     PROJ at lists.osgeo.org
>     https://lists.osgeo.org/mailman/listinfo/proj
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20221005/62d7f936/attachment.htm>
More information about the PROJ mailing list
