[PROJ] Equirectangular/Equidistant Cylindrical
Even Rouault even.rouault at spatialys.com
Thu Oct 13 06:38:21 PDT 2022
Access to the PDF to try spotting the cause of the
"proj_create_from_database: crs not found" error & possibly solving it
would still be interesting
Le 13/10/2022 à 15:31, Andrew Patterson a écrit :
> Even,
> So while I was writing up the issue I realized I could probably
> provide some simple code to help illustrate the problem, so I wrote
> some. Then I realized I should really run it in our old app as well,
> which took a while -- which is why you're reading this today rather
> than yesterday. But in the course of doing this, I basically proved
> that PROJ is fine, so there's no reason to create the issue. So false
> alarm!
> Plotting on the maps is a two step process; coordinate transform via
> PROJ from WGS84 to the map's projection, then run that coordinate
> through a world-to-page (i.e. pixel) transform. The latter is *really*
> easy to test so that's always the first thing I verify. Once that's
> been done, the problem basically has to lie with the PROJ transform --
> and this has been true until now. I'm actually quite perplexed. If
> both parts of a two-part transformation are fine, why is everything
> shifted? Something is hinky, but that's my problem not yours, so I
> apologize for wasting your time with this. I think I also jumped the
> gun because of problems with Equidistant Cylindrical in the past, but
> for once, that project is innocent.
> Again, sorry for the trouble!
http://www.spatialys.com
More information about the PROJ mailing list
