[PROJ] Danish_System_34_Sjaelland
Javier Jimenez Shaw j1 at jimenezshaw.com
Mon Aug 14 15:18:12 PDT 2023
Hi
I got this wkt, which projection "Transverse Mercator Sjaelland" is not
supported by PROJ
PROJCS["Danish_System_34_Sjaelland", GEOGCS["GCS_European 1950",
DATUM["D_European 1950",
SPHEROID["International_1924",6378388.000000,297.000000]],
PRIMEM["Greenwich",0.000000], UNIT["Degree",0.017453292519943295]],
PROJECTION["Transverse Mercator Sjaelland"],
PARAMETER["Scale_Factor",0.999600], PARAMETER["Central_Meridian",9.000000],
PARAMETER["False_Easting",500000.000000], UNIT["Meter",1.000000000000]]
Seems to be something very Danish specific, and quite old. Do you know any
equivalent wkt that may work in PROJ? There were some Danish grid files
added recently for S34
Thanks
Javier
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230815/8b036a2c/attachment.htm>
More information about the PROJ mailing list
