[PROJ] Danish_System_34_Sjaelland
Thomas Knudsen knudsen.thomas at gmail.com
Mon Aug 14 19:46:18 PDT 2023
That definition definitely looks odd. The correct EPSG id for System 34
Sjælland
is 10250 (and its companion for the western part of Denmark, "System 34
Jylland"
is EPSG:10160).
For historical reasons, those systems are utterly odd: They originated as
cadastral
systems, and the cadastre did not really care about the absolute
orientation of
the systems, hence ignoring (at that time, i.e. 1930-ish), existing
astro-geodetic
observations, to the effect that what was specified as a transverse cylinder
projection actually ended up as oblique.
Which also means, as noted by Mikael Rittri a decade ago on this mailing
list, that System 34 can be approximated at the metre level by an oblique
mercator
(proj=omerc).
The reconstructions we recently submitted to the EPSG, are based on
transverse
mercator, but use grid based datum shifts to correct for the
mis-orientation and
network tensions.
Den tirs. 15. aug. 2023 kl. 00.18 skrev Javier Jimenez Shaw <
j1 at jimenezshaw.com>:
> Hi
> I got this wkt, which projection "Transverse Mercator Sjaelland" is not
> supported by PROJ
> PROJCS["Danish_System_34_Sjaelland", GEOGCS["GCS_European 1950",
> DATUM["D_European 1950",
> SPHEROID["International_1924",6378388.000000,297.000000]],
> PRIMEM["Greenwich",0.000000], UNIT["Degree",0.017453292519943295]],
> PROJECTION["Transverse Mercator Sjaelland"],
> PARAMETER["Scale_Factor",0.999600],
> PARAMETER["Central_Meridian",9.000000],
> PARAMETER["False_Easting",500000.000000], UNIT["Meter",1.000000000000]]
> Seems to be something very Danish specific, and quite old. Do you know any
> equivalent wkt that may work in PROJ? There were some Danish grid files
> added recently for S34
> Thanks
> Javier
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230815/2d6caab9/attachment.htm>
More information about the PROJ mailing list
