[PROJ] PROJ 9.3.1RC1 & PROJ-data 1.16RC1
Charles Karney charles.karney at gmail.com
Fri Dec 1 01:52:20 PST 2023
+1
   --Charles
On 12/1/23 00:53, Kristian Evers via PROJ wrote:
> PSC members,
> No issues have been reported with the two release candidates so I motion that they
> are promoted to final releases.
> I’ll start with my +1.
> /Kristian
>> On 26 Nov 2023, at 20.01, Even Rouault <even.rouault at spatialys.com> wrote:
>> Hi Kristian,
>> The archives looks good to me.
>> Even
>> Le 26/11/2023 à 17:48, Kristian Evers via PROJ a écrit :
>>> All,
>>> It’s time for another round of releases, so in preparation for the final packages I have uploaded
>>>   release candidates for PROJ and PROJ-data. Download the archives here:
>>> https://download.osgeo.org/proj/proj-9.3.1RC1.tar.gz
>>> https://download.osgeo.org/proj/proj-9.3.1RC1.zip
>>>    https://download.osgeo.org/proj/proj-data-1.16RC1.tar.gz
>>> https://download.osgeo.org/proj/proj-data-1.16RC1.zip
>>> The PROJ release includes updates to the database contents and bug fixes. See the release notes below.
>>> The PROJ-data release adds the German geoid model GCG2016.
>>> Please test the release candidates and report any issues you may find with them. Either here
>>> on the mailing list or on GitHub.
>>> /Kristian
>>> 9.3.1 Release Notes
>>>   Updates
>>>   o Update to EPSG 10.098 (#3968)
>>>   o Update ESRI objects to v3.2.0 (#3944)
>>>   Bug fixes
>>>   o ITRF2008: fix wrong sign for 'dry' parameter of EURA and EURA_T  (#3870)
>>>   o Fix build error with MSVC 2019 in /std:c++20 on NN_NO_CHECK() (#3872)
>>>   o  ESRI WKT import: normalize GCS_unknown to unknown and D_unknown to unknown (#3874)
>>>   o CoordinateOperationFactory: deal with CompoundToCompound with a horizontal similarity
>>>     transformation and a ballpark vertical (#3881)
>>>   o Ellipsoid::_isEquivalentTo(): fix so that an ellipsoid of semi-major axis A (and
>>>     non-zero inv flattening) isn't equivalent to a sphere of radius A (#3882)
>>>   o isEquivalentTo(): make a datum name 'unknown' equivalent to another one (#3883)
>>>   o cs2cs: fix handling of input coordinates in grad (#3886)
>>>   o Make setargv.obj available on Universal Windows Platform (#3891)
>>>   o Allow opening proj.db with a URI (#3892)
>>>   o createOperations(): fix GeogCRS 3D with TOWGS84 to geocentric CRS (#3915)
>>>   o Fix test suite so that it can pass with ENABLE_TIFF=OFF (#3916)
>>>   o GeographicBoundingBox::intersects(): avoid infinite recursion and stack overflow
>>>     on invalid bounding boxes (#3919)
>>>   o Fix importing '+proj=topocentric ... +type=crs' by using a geocentric CRS as
>>>     the base CRS (#3924)
>>>   o Allow LOCAL_CS with 3 axes (#3928)
>>>   o WKT1 parser: in non-strict mode, accept missing UNIT[] in GEOGCS, GEOCCS,
>>>     PROJCS and VERT_CS elements (#3933)
>>>   o createOperations(): fix issue with a obscure case involving CompoundCRS of
>>>     unknown horizontal datum + boundCRS of vertical (#3934)
>>>   o createOperations(): fix bad PROJ pipeline when converting between Geog3D
>>>     with non-metre height to CompoundCRS (#3943)
>>>   o createOperations(): Fix possible null dereference on invalid WKT input (#3946)
>>>   o proj_factor: fix when input is a compound CRS of a projected CRS (#3950)
>>>   o pj_get_suggested_operation(): tune it to give correct result for RGAF09 to
>>>     RRAF 1991 / UTM zone 20N + Guadeloupe 1988 height transformation (#3954)
>>>   o Move static NameSpace::GLOBAL definition in static.cpp to avoid
>>>    'static initialization fiasco' (#3956)
>>>   o horner: allow arbitrary input type of coordinate (#3961)
>>> PROJ mailing list
>>> PROJ at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/proj
>> http://www.spatialys.com
>> My software is free, but my time generally not.
> PROJ mailing list
Charles Karney <karney at alum.mit.edu>
702 Prospect Ave
Princeton, NJ 08540-4037
More information about the PROJ mailing list
