[PROJ] PROJ 9.3.1RC1 & PROJ-data 1.16RC1
Javier Jimenez Shaw j1 at jimenezshaw.com
Fri Dec 1 02:07:02 PST 2023
+1 Javier
On Fri, 1 Dec 2023 at 10:52, Charles Karney via PROJ <proj at lists.osgeo.org>
wrote:
> +1
>    --Charles
> On 12/1/23 00:53, Kristian Evers via PROJ wrote:
> > PSC members,
> > No issues have been reported with the two release candidates so I motion
> that they
> > are promoted to final releases.
> > I’ll start with my +1.
> > /Kristian
> >> On 26 Nov 2023, at 20.01, Even Rouault <even.rouault at spatialys.com>
> wrote:
> >> Hi Kristian,
> >> The archives looks good to me.
> >> Even
> >> Le 26/11/2023 à 17:48, Kristian Evers via PROJ a écrit :
> >>> All,
> >>> It’s time for another round of releases, so in preparation for the
> final packages I have uploaded
> >>>   release candidates for PROJ and PROJ-data. Download the archives
> here:
> >>> https://download.osgeo.org/proj/proj-9.3.1RC1.tar.gz
> >>> https://download.osgeo.org/proj/proj-9.3.1RC1.zip
> >>>    https://download.osgeo.org/proj/proj-data-1.16RC1.tar.gz
> >>> https://download.osgeo.org/proj/proj-data-1.16RC1.zip
> >>> The PROJ release includes updates to the database contents and bug
> fixes. See the release notes below.
> >>> The PROJ-data release adds the German geoid model GCG2016.
> >>> Please test the release candidates and report any issues you may find
> with them. Either here
> >>> on the mailing list or on GitHub.
> >>> /Kristian
> >>> 9.3.1 Release Notes
> >>>   Updates
> >>>   o Update to EPSG 10.098 (#3968)
> >>>   o Update ESRI objects to v3.2.0 (#3944)
> >>>   Bug fixes
> >>>   o ITRF2008: fix wrong sign for 'dry' parameter of EURA and EURA_T
> (#3870)
> >>>   o Fix build error with MSVC 2019 in /std:c++20 on NN_NO_CHECK()
> (#3872)
> >>>   o  ESRI WKT import: normalize GCS_unknown to unknown and D_unknown
> to unknown (#3874)
> >>>   o CoordinateOperationFactory: deal with CompoundToCompound with a
> horizontal similarity
> >>>     transformation and a ballpark vertical (#3881)
> >>>   o Ellipsoid::_isEquivalentTo(): fix so that an ellipsoid of
> semi-major axis A (and
> >>>     non-zero inv flattening) isn't equivalent to a sphere of radius A
> (#3882)
> >>>   o isEquivalentTo(): make a datum name 'unknown' equivalent to
> another one (#3883)
> >>>   o cs2cs: fix handling of input coordinates in grad (#3886)
> >>>   o Make setargv.obj available on Universal Windows Platform (#3891)
> >>>   o Allow opening proj.db with a URI (#3892)
> >>>   o createOperations(): fix GeogCRS 3D with TOWGS84 to geocentric CRS
> (#3915)
> >>>   o Fix test suite so that it can pass with ENABLE_TIFF=OFF (#3916)
> >>>   o GeographicBoundingBox::intersects(): avoid infinite recursion and
> stack overflow
> >>>     on invalid bounding boxes (#3919)
> >>>   o Fix importing '+proj=topocentric ... +type=crs' by using a
> geocentric CRS as
> >>>     the base CRS (#3924)
> >>>   o Allow LOCAL_CS with 3 axes (#3928)
> >>>   o WKT1 parser: in non-strict mode, accept missing UNIT[] in GEOGCS,
> GEOCCS,
> >>>     PROJCS and VERT_CS elements (#3933)
> >>>   o createOperations(): fix issue with a obscure case involving
> CompoundCRS of
> >>>     unknown horizontal datum + boundCRS of vertical (#3934)
> >>>   o createOperations(): fix bad PROJ pipeline when converting between
> Geog3D
> >>>     with non-metre height to CompoundCRS (#3943)
> >>>   o createOperations(): Fix possible null dereference on invalid WKT
> input (#3946)
> >>>   o proj_factor: fix when input is a compound CRS of a projected CRS
> (#3950)
> >>>   o pj_get_suggested_operation(): tune it to give correct result for
> RGAF09 to
> >>>     RRAF 1991 / UTM zone 20N + Guadeloupe 1988 height transformation
> (#3954)
> >>>   o Move static NameSpace::GLOBAL definition in static.cpp to avoid
> >>>    'static initialization fiasco' (#3956)
> >>>   o horner: allow arbitrary input type of coordinate (#3961)
> >>> _______________________________________________
> >>> PROJ mailing list
> >>> PROJ at lists.osgeo.org
> >>> https://lists.osgeo.org/mailman/listinfo/proj
> >> http://www.spatialys.com
> >> My software is free, but my time generally not.
> > PROJ mailing list
> Charles Karney <karney at alum.mit.edu>
> 702 Prospect Ave
> Princeton, NJ 08540-4037
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20231201/3f0c8613/attachment-0001.htm>
More information about the PROJ mailing list
