[PROJ] PROJ 9.3.1RC1 & PROJ-data 1.16RC1
Kristian Evers kristianevers at gmail.com
Fri Dec 1 10:49:10 PST 2023
I declare the motion passed with +1’s from
Kristian
Thomas
Charles
Javier
Even
Alan
Expect a release announcement soon.
/Kristian
> On 1 Dec 2023, at 14.46, Alan Snow via PROJ <proj at lists.osgeo.org> wrote:
> +1 Alan
> On Thu, Nov 30, 2023, 11:53 PM Kristian Evers via PROJ <proj at lists.osgeo.org <mailto:proj at lists.osgeo.org>> wrote:
> PSC members,
> No issues have been reported with the two release candidates so I motion that they
> are promoted to final releases.
> I’ll start with my +1.
> /Kristian
> > On 26 Nov 2023, at 20.01, Even Rouault <even.rouault at spatialys.com <mailto:even.rouault at spatialys.com>> wrote:
> > Hi Kristian,
> > The archives looks good to me.
> > Even
> > Le 26/11/2023 à 17:48, Kristian Evers via PROJ a écrit :
> >> All,
> >> It’s time for another round of releases, so in preparation for the final packages I have uploaded
> >>  release candidates for PROJ and PROJ-data. Download the archives here:
> >> https://download.osgeo.org/proj/proj-9.3.1RC1.tar.gz <https://download.osgeo.org/proj/proj-9.3.1RC1.tar.gz>
> >> https://download.osgeo.org/proj/proj-9.3.1RC1.zip <https://download.osgeo.org/proj/proj-9.3.1RC1.zip>
> >>   https://download.osgeo.org/proj/proj-data-1.16RC1.tar.gz <https://download.osgeo.org/proj/proj-data-1.16RC1.tar.gz>
> >> https://download.osgeo.org/proj/proj-data-1.16RC1.zip <https://download.osgeo.org/proj/proj-data-1.16RC1.zip>
> >> The PROJ release includes updates to the database contents and bug fixes. See the release notes below.
> >> The PROJ-data release adds the German geoid model GCG2016.
> >> Please test the release candidates and report any issues you may find with them. Either here
> >> on the mailing list or on GitHub.
> >> /Kristian
> >> 9.3.1 Release Notes
> >>  Updates
> >>  o Update to EPSG 10.098 (#3968)
> >>  o Update ESRI objects to v3.2.0 (#3944)
> >>  Bug fixes
> >>  o ITRF2008: fix wrong sign for 'dry' parameter of EURA and EURA_T  (#3870)
> >>  o Fix build error with MSVC 2019 in /std:c++20 on NN_NO_CHECK() (#3872)
> >>  o  ESRI WKT import: normalize GCS_unknown to unknown and D_unknown to unknown (#3874)
> >>  o CoordinateOperationFactory: deal with CompoundToCompound with a horizontal similarity
> >>    transformation and a ballpark vertical (#3881)
> >>  o Ellipsoid::_isEquivalentTo(): fix so that an ellipsoid of semi-major axis A (and
> >>    non-zero inv flattening) isn't equivalent to a sphere of radius A (#3882)
> >>  o isEquivalentTo(): make a datum name 'unknown' equivalent to another one (#3883)
> >>  o cs2cs: fix handling of input coordinates in grad (#3886)
> >>  o Make setargv.obj available on Universal Windows Platform (#3891)
> >>  o Allow opening proj.db with a URI (#3892)
> >>  o createOperations(): fix GeogCRS 3D with TOWGS84 to geocentric CRS (#3915)
> >>  o Fix test suite so that it can pass with ENABLE_TIFF=OFF (#3916)
> >>  o GeographicBoundingBox::intersects(): avoid infinite recursion and stack overflow
> >>    on invalid bounding boxes (#3919)
> >>  o Fix importing '+proj=topocentric ... +type=crs' by using a geocentric CRS as
> >>    the base CRS (#3924)
> >>  o Allow LOCAL_CS with 3 axes (#3928)
> >>  o WKT1 parser: in non-strict mode, accept missing UNIT[] in GEOGCS, GEOCCS,
> >>    PROJCS and VERT_CS elements (#3933)
> >>  o createOperations(): fix issue with a obscure case involving CompoundCRS of
> >>    unknown horizontal datum + boundCRS of vertical (#3934)
> >>  o createOperations(): fix bad PROJ pipeline when converting between Geog3D
> >>    with non-metre height to CompoundCRS (#3943)
> >>  o createOperations(): Fix possible null dereference on invalid WKT input (#3946)
> >>  o proj_factor: fix when input is a compound CRS of a projected CRS (#3950)
> >>  o pj_get_suggested_operation(): tune it to give correct result for RGAF09 to
> >>    RRAF 1991 / UTM zone 20N + Guadeloupe 1988 height transformation (#3954)
> >>  o Move static NameSpace::GLOBAL definition in static.cpp to avoid
> >>   'static initialization fiasco' (#3956)
> >>  o horner: allow arbitrary input type of coordinate (#3961)
> >> _______________________________________________
> >> PROJ mailing list
> >> PROJ at lists.osgeo.org <mailto:PROJ at lists.osgeo.org>
> >> https://lists.osgeo.org/mailman/listinfo/proj <https://lists.osgeo.org/mailman/listinfo/proj>
> > http://www.spatialys.com <http://www.spatialys.com/>
> > My software is free, but my time generally not.
> PROJ mailing list
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20231201/3a9e5b61/attachment-0001.htm>
More information about the PROJ mailing list
