[PROJ] PROJ 9.3.1 & PROJ-data 1.16
Kristian Evers kristianevers at gmail.com
Fri Dec 1 11:47:59 PST 2023
I'm happy to announce the release of PROJ 9.3.1 and PROJ-data 1.16!
The PROJ release includes updates to the the database contents, as well as
a number of bug fixes. See the release notes below.
The PROJ-data release adds the German geoid model GCG2016.
Download the archives here:
http://download.osgeo.org/proj/proj-9.3.1.tar.gz
http://download.osgeo.org/proj/proj-9.3.1.zip
http://download.osgeo.org/proj/proj-data-1.16.tar.gz
http://download.osgeo.org/proj/proj-data-1.16.zip /Kristian
/Kristian
9.3.1 Release Notes
 Updates
 o Update to EPSG 10.098 (#3968)
 o Update ESRI objects to v3.2.0 (#3944)
 Bug fixes
 o ITRF2008: fix wrong sign for 'dry' parameter of EURA and EURA_T  (#3870)
 o Fix build error with MSVC 2019 in /std:c++20 on NN_NO_CHECK() (#3872)
 o  ESRI WKT import: normalize GCS_unknown to unknown and D_unknown to unknown (#3874)
 o CoordinateOperationFactory: deal with CompoundToCompound with a horizontal similarity
   transformation and a ballpark vertical (#3881)
 o Ellipsoid::_isEquivalentTo(): fix so that an ellipsoid of semi-major axis A (and
   non-zero inv flattening) isn't equivalent to a sphere of radius A (#3882)
 o isEquivalentTo(): make a datum name 'unknown' equivalent to another one (#3883)
 o cs2cs: fix handling of input coordinates in grad (#3886)
 o Make setargv.obj available on Universal Windows Platform (#3891)
 o Allow opening proj.db with a URI (#3892)
 o createOperations(): fix GeogCRS 3D with TOWGS84 to geocentric CRS (#3915)
 o Fix test suite so that it can pass with ENABLE_TIFF=OFF (#3916)
 o GeographicBoundingBox::intersects(): avoid infinite recursion and stack overflow
   on invalid bounding boxes (#3919)
 o Fix importing '+proj=topocentric ... +type=crs' by using a geocentric CRS as
   the base CRS (#3924)
 o Allow LOCAL_CS with 3 axes (#3928)
 o WKT1 parser: in non-strict mode, accept missing UNIT[] in GEOGCS, GEOCCS,
   PROJCS and VERT_CS elements (#3933)
 o createOperations(): fix issue with a obscure case involving CompoundCRS of
   unknown horizontal datum + boundCRS of vertical (#3934)
 o createOperations(): fix bad PROJ pipeline when converting between Geog3D
   with non-metre height to CompoundCRS (#3943)
 o createOperations(): Fix possible null dereference on invalid WKT input (#3946)
 o proj_factor: fix when input is a compound CRS of a projected CRS (#3950)
 o pj_get_suggested_operation(): tune it to give correct result for RGAF09 to
   RRAF 1991 / UTM zone 20N + Guadeloupe 1988 height transformation (#3954)
 o Move static NameSpace::GLOBAL definition in static.cpp to avoid
  'static initialization fiasco' (#3956)
 o horner: allow arbitrary input type of coordinate (#3961)
More information about the PROJ mailing list
