[PROJ] EPSG:1104
Even Rouault even.rouault at spatialys.com
Fri Dec 15 04:53:15 PST 2023
Torill,
the area of use of EPSG:1104 is
     USAGE[
         SCOPE["Military survey."],
         AREA["Mali."],
         BBOX[10.14,-12.25,25.01,4.26]],
with this very interesting remark:
     REMARK["Derived at 1 station connected to the Adindan (Blue Nile
1958) network through the 1968-69 12th parallel traverse. Accuracy 25m
in each axis. Note: the Adindan (Blue Nile 1958) CRS is used in Ethiopia
and Sudan, not Mali."]]
The area of use of EPSG:4201 is
     USAGE[
         SCOPE["Geodesy."],
         AREA["Eritrea; Ethiopia; South Sudan; Sudan."],
         BBOX[3.4,21.82,22.24,47.99]],
So there is no intersection between both, hence EPSG:1104 is discarded.
Even
Le 15/12/2023 à 12:01, Torill Kjøsnes Gabrielsen via PROJ a écrit :
> Hi,
> I am writing to inquire about the availability of the EPSG:1104
> transformation in PROJ 9.3.1 and 9.2. I have noticed that PROJ
> supports the EPSG:1104 coordinate operation method;
> /projinfo //urn:ogc:def:coordinateOperation:EPSG::1104/.
> However, when I try to use this transformation in the projinfo command
> for transformation between coordinates expressed in EPSG:4201 and
> EPSG:4326, the EPSG:1104 method is not listed as a candidate;
> projinfo -s 'EPSG:4201' -t 'EPSG:4326' -o PROJ --spatial-test
> intersects --show-superseded
> As far as I know, the EPSG:1104 transformation is a valid 3-parameter
> transformation and should be applicable for transforming coordinates
> between these two CRSs. Therefore, I was wondering if there is a
> reason why this transformation is not listed as a candidate by the
> projinfo command.
> Thanks for your help and support.
> Best regards,
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20231215/0f4eda01/attachment.htm>
More information about the PROJ mailing list
