[PROJ] about read the docs
Javier Jimenez Shaw j1 at jimenezshaw.com
Fri Feb 3 09:30:08 PST 2023
Hi
due to problems in https://proj.org, I went to read documenation at
https://osgeo-proj.readthedocs.io/ ... and the surprise was that it
redirected to https://pointcloud.org/ Is that intentional (it looks like)
and temporary?
Another topic: in the applications, for instance
https://pointcloud.org/en/9.1/apps/projinfo.html , the parameters with two
dashes (like –spatial-test) appears with a single long dash, instead of two
dashes. Later below it appears correctly with two: --spatial-test
I was confused (my memory is not great). I assume that the formatting is
done automatically, but it would be clearer with the actual symbol in case
anybody copy-pastes it.
Cheers.
Javier
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230203/b3bcdd20/attachment.htm>
More information about the PROJ mailing list
