[PROJ] National CRS to ITRS
Even Rouault even.rouault at spatialys.com
Mon Feb 20 04:51:29 PST 2023
Jochem
> *RDNAP to ITRF2014:*
> echo 128410.0957 445806.4960 -0.4754 2023.00 | cs2cs epsg:7415
> epsg:7912 -d 9
> The result is a null transformation, which is _not_ what we recommend:
> 52.00000_0000_ 5.00000_0000_ 43.0_000_ 2023.00
You didn't mention which PROJ version you use. But starting with 9.1.0,
here's the result I get:
$ echo 128410.0957 445806.4960 -0.4754 2023.00 | PROJ_NETWORK=ON
PROJ_DEBUG=2 bin/cs2cs epsg:7415 epsg:7912 -d 9
Using coordinate operation Inverse of RD New + Amersfoort to ETRS89 (9)
+ Inverse of ETRS89 to NAP height (2) + Null geographic offset from
ETRS89 (geog3D) to ETRS89 (geog2D) + ETRS89 to ETRF2014 + Conversion
from ETRF2014 (geog2D) to ETRF2014 (geocentric) + Inverse of ITRF2014 to
ETRF2014 (2) + Conversion from ITRF2014 (geocentric) to ITRF2014 (geog3D)
52.000004918    5.000008844 43.001783708 2023.00
This is the first pipeline suggested by projinfo -s epsg:7415 -t epsg:7912:
unknown id, Inverse of RD New + Amersfoort to ETRS89 (9) + Inverse of
ETRS89 to NAP height (2) + Null geographic offset from ETRS89 (geog3D)
to ETRS89 (geog2D) + ETRS89 to ETRF2014 + Conversion from ETRF2014
(geog2D) to ETRF2014 (geocentric) + Inverse of ITRF2014 to ETRF2014 (2)
+ Conversion from ITRF2014 (geocentric) to ITRF2014 (geog3D), 0.102 m,
Netherlands - onshore, including Waddenzee, Dutch Wadden Islands and
12-mile offshore coastal zone., at least one grid missing
PROJ string:
+proj=pipeline
   +step +inv +proj=sterea +lat_0=52.1561605555556 +lon_0=5.38763888888889
         +k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel
   +step +proj=hgridshift +grids=nl_nsgi_rdtrans2018.tif
   +step +proj=vgridshift +grids=nl_nsgi_nlgeo2018.tif +multiplier=1
   +step +proj=cart +ellps=GRS80
   +step +inv +proj=helmert +x=0 +y=0 +z=0 +rx=0.001785 +ry=0.011151
+rz=-0.01617
         +s=0 +dx=0 +dy=0 +dz=0 +drx=8.5e-05 +dry=0.000531 +drz=-0.00077
+ds=0
         +t_epoch=2010 +convention=position_vector
   +step +inv +proj=cart +ellps=GRS80
   +step +proj=unitconvert +xy_in=rad +xy_out=deg
   +step +proj=axisswap +order=2,1
So this kind of works, but using the ETRS89 -> ETRF2014 direct
transformation, not through the ETRF2000 -> ETRF2014 one you expect,
which is quite logical since NAP height is only linked to ETRS89.
> I assume that the best way to fix this is to ask EPSG to link RDNAP to
> ETRF2000 instead of the ETRS89 datum ensemble. Would that indeed solve
> the problem in PROJ?
I wouldn't say "instead", but "in addition". There should likely be a
ETRF2014 to NAP height transformation, and a Amersfoort to ETRF2014 one
(that could be a concatenation of Amersfoort to ETRS89 (9) + ETRS89 ->
ETRF2000 + ETRF2000 -> ETRF2014  or Amersfoort to ETRS89 (9) + ETRS89 ->
ETRF2014 depending on your preference)
> Kind regards, Jochem
> Disclaimer:
> De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor
> de geadresseerde(n).
> Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of
> verstrekking van deze informatie aan derden is niet toegestaan.
> Op al onze producten en diensten zijn onze algemene
> leveringsvoorwaarden van toepassing
> [https://www.kadaster.nl/algemene-leveringsvoorwaarden].
> Disclaimer:
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they
> are addressed.
> If you are not the intended recipient, you are notified that
> disclosing, copying, distributing or taking any action in reliance on
> the contents of this information is strictly prohibited.
> Our general terms and conditions of delivery apply to all our products
> and services
> [https://www.kadaster.com/general-terms-and-conditions].
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230220/eda7af94/attachment.htm>
More information about the PROJ mailing list
