[PROJ] National CRS to ITRS
Lesparre, Jochem Jochem.Lesparre at kadaster.nl
Tue Feb 21 02:00:16 PST 2023
Dear Even,
Sorry, I was using PROJ 8.2.1 as I didn’t expect the PROJ behaviour had changed since that version (see updated command results below).
We use the ETRF2000 realisation like most other NMAs, as this is recommended by EUREF for georeferencing, not ETRF2014! Therefore, ETRS89 should not be transformed to ETRF2014 with a null transformation. The correct transformation routes are:
  *   RD -> Amersfoort -> ETRF2000 -> ITRF2000 -> ITRF2014
  *   NAP -> ETRF2000 -> ITRF2000 -> ITRF2014
I expected this could be achieved by changing the Amersfoort-ETRS89 transformation to Amersfoort-ETRF2000 “instead” in EPSG. I don’t understand what advantage a transformation to the ETRS89 datum ensemble “in addition” to a transformation to the specific ETRF2000 realisation in EPSG would give.
In PROJ 9.1.1. RDNAP to ITRF2014:
echo 128410.0957 445806.4960 -0.4754 2023.00 | cs2cs epsg:7415 epsg:7912 -d 9
Gives:
52.000004918 5.000008844 43.0018 2023.00
This should be:
52.000005512 5.000008256 43.0197 2023.00
Like RDNAP via ETRF2000 to ITRF2014:
echo 128410.0957 445806.4960 -0.4754 2023.00 | cs2cs epsg:7415 epsg:7931 -d 9 | cs2cs epsg:7931 epsg:7912 -d 9
In PROJ 9.1.1. RDNAP to WGS84:
echo 128410.0957 445806.4960 -0.4754 2023.00 | cs2cs epsg:7415 epsg:4326 -d 9
Gives:
51.999999889 5.000000153 -0.4754 2023.00
This should be:
52.000000000 5.000000000 43.0000 2023.00
Like RDNAP via ETRF2000 to WGS84:
echo 128410.0957 445806.4960 -0.4754 2023.00 | cs2cs epsg:7415 epsg:7931 -d 9 | cs2cs epsg:7931 epsg:4326 -d 9
Kind regards, Jochem
Disclaimer:
De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de geadresseerde(n).
Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of verstrekking van deze informatie aan derden is niet toegestaan.
Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden van toepassing
[https://www.kadaster.nl/algemene-leveringsvoorwaarden].
Disclaimer:
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Our general terms and conditions of delivery apply to all our products and services
[https://www.kadaster.com/general-terms-and-conditions].
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230221/5eeee524/attachment.htm>
More information about the PROJ mailing list
