[PROJ] Bumping SONAME for PROJ 9.2 for changes in PJ_LOG_LEVEL ?
Even Rouault even.rouault at spatialys.com
Thu Jan 5 07:27:50 PST 2023
asking feedback of the PSC regarding a point of
https://github.com/OSGeo/PROJ/pull/3535
I've added a new PJ_LOG_WARNING level in the public PJ_LOG_LEVEL
enumeration. Ideally this level should be between PJ_LOG_ERROR and
PJ_LOG_DEBUG, but the first is assigned integer value 1 and the later 2.
So there's no room to make it fit naturally
In the current state of the PR, I've allocated PJ_LOG_WARNING=10, and
added an helper function that enables to logically compare log levels.
But I recognize that's a bit convoluted.
I'd be leaning towards the following: for PROJ 9.2, modify PJ_LOG_LEVEL
as below (letting some space if the need for new values arise in the
future), and bump the SONAME version number from 25 to 26 to acknowledge
the ABI breakage (but keep the PROJ 9.2 "user" version number to reflect
this is mostly a transparent change that shouldn't require more than
rebuilding software against modified proj.h)
typedef enum PJ_LOG_LEVEL {
     PJ_LOG_NONE  = 0,
     PJ_LOG_ERROR = 10,
     PJ_LOG_WARNING = 20,
     PJ_LOG_DEBUG = 30,
     PJ_LOG_TRACE = 40,
     PJ_LOG_TELL  = 50,
     PJ_LOG_DEBUG_MAJOR = PJ_LOG_DEBUG, /* for proj_api.h compatibility */
     PJ_LOG_DEBUG_MINOR = PJ_LOG_TRACE  /* for proj_api.h compatibility */
} PJ_LOG_LEVEL;
(Just realizing that some command line utilities, like cct that can take
-v, -vv, -vvv to adjust the verbosity level will have to be adjusted as
there will no longer be a direct mapping between the number of
repetitions and the value of PJ_LOG_LEVEL, but that's OK)
Even
http://www.spatialys.com
More information about the PROJ mailing list
