[PROJ] Interface to PROJ from C#
Paul Harwood runette at gmail.com
Fri Jan 6 03:48:43 PST 2023
I might have to apologize - I did not spot this was a continuation of a
previous email chain :) I don't know why the context was lost
On Fri, 6 Jan 2023 at 10:07, Paul Harwood <runette at gmail.com> wrote:
> HI
> Might I politely suggest that you should think about asking effective
> questions? It is not clear from this what you are actually asking.
> My interpretation is that the vcpkg thing is not the question (so it would
> be nice if that was not the start of the email - it is FYI info).
> It looks like you are asking for help with PInvoke and Proj in C#. That is
> not going to be an easy ask - since it is not a supported environment in
> Proj and PInvoke is at best a dark art.
> It is not clear from the question if proj_create_crs_to_crs is a method
> that works or one that does not work. If it does not work - what is the
> problem/error message?
> As a general note - what I do since I do not want to have an unsupported
> Pinvoke interface is to use GDAL. This has supported C# bindings and does
> expose at least some of the Proj functionality as the OSR ABI. Not an ideal
> solution but workable and supported.
> On Thu, 5 Jan 2023 at 20:27, Jason Dick <JasonD at thetranstecgroup.com>
> wrote:
>> I used vcpkg. I used the instructions from the web site:
>> https://proj.org/install.html
>> It did take me awhile to get it working because I needed to customize the
>> process. But now that the DLL is built by default, that's less necessary.
>> I only use a handful of functions and there are some that I didn't know
>> how to convert to C#. Here's an example of one import that I use.
>> private const String ProjDLL = "proj.dll";
>> // PJ *proj_create_crs_to_crs(PJ_CONTEXT *ctx, const char *source_crs,
>> const char *target_crs, PJ_AREA *area)
>> [DllImport(ProjDLL, CallingConvention = CallingConvention.Cdecl, CharSet
>> = CharSet.Ansi, BestFitMapping = false, ThrowOnUnmappableChar = true)]
>> private static extern IntPtr proj_create_crs_to_crs(IntPtr ctx, String
>> source_crs, String target_crs, IntPtr area);
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230106/7d10d1cb/attachment.htm>
More information about the PROJ mailing list
