[PROJ] Latitude of natural origin in Transverse Mercator
Even Rouault even.rouault at spatialys.com
Fri Jan 13 07:13:11 PST 2023
Hi Javier,
interesting. Quick numerical experimentation seems to confirm that they
are "equivalent", as well as looking at the drawing of how the
projection is built.
And looking at the maths of the approximate ellipsoidal forward method
in src/projections/tmerc.cpp, one can see:
xy.y = P->k0 * (.... - Q->ml0 + ....... )
(the false northing value is added in generic PROJ code)
where
Q->ml0 = pj_mlfn(P->phi0, sin(P->phi0), cos(P->phi0), Q->en);
where pj_mlfn() computes the meridional distance (formula in src/mlfn.cpp)
So - P->k0 * Q->ml0 should be the value of the false northing equivalent
to the effect of phi0. (I believe :-))
Also confirmed by the formula N=N0 +y(lam,phi) - k0 * m(phi0) of
https://en.wikipedia.org/wiki/Transverse_Mercator_projection#Coordinates,_grids,_eastings_and_northings
Even
Le 13/01/2023 à 15:28, Javier Jimenez Shaw a écrit :
> Hi
> I have a question about Transverse Mercator.
> What is the impact of the parameter "Latitude of natural origin",
> compared with the "False Northing"? (apart from the fact that one is
> in degrees and the other in meters)
> Is there any difference on using a Latitude of natural origin of,
> let's say, 40 degrees, or compute the equivalent False Northing?
> Thanks.
> Javier
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230113/28668878/attachment.htm>
More information about the PROJ mailing list
