[PROJ] about request #3246 - defining second CRS for EPSG6316 with area extend EPSG1148 and transformation EPSG6206 within PROJ for North Macedonia
support at mnspoint.com support at mnspoint.com
Mon Jan 23 00:35:47 PST 2023
Dear,
"In QGIS 3.26.0 version, , in list of Coordinate Reference Systems
(CRS), CRS with code EPSG 6316 doesn't cover area of North Macedonia.
With this, North Macedonian CRS based on EPSG 6316 parameters cannot be
used in QGIS. Situation should be same in all software which use proj
and epsg databases for CRS’s."
No, we do not have this issue, since we do not limit the "area of use"
of any projection-datum (the projection itself might have some
singularities and limits, but that is usual near poles, etc.)
Janne.
Bashkim IDRIZI via PROJ kirjoitti 2023-01-22 18:00:
> Macedonia
> Dear all,
> The issue 3246 is open from July 2022.
> Main problem to be solved is separating EPSG 6316 into two separate
> CRS's within PROJ, since it has two area extends
> (https://epsg.org/crs_6316/MGI-1901-Balkans-zone-7.html?sessionkey=pvenyf6ze2).
> Details are given in https://github.com/OSGeo/PROJ/issues/3246.
> I kindly ask You to assist in order to solve this problem.
> Kind regards,
> Bashkim.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
