[PROJ] about request #3246 - defining second CRS for EPSG6316 with area extend EPSG1148 and transformation EPSG6206 within PROJ for North Macedonia
Even Rouault even.rouault at spatialys.com
Mon Jan 23 05:35:40 PST 2023
Bashkim,
I've just submitted https://github.com/OSGeo/PROJ/pull/3588 so that code
using PROJ API can retrieve multiple extents when there are. With that,
QGIS should have the possibility to better use the metadata of
EPSG:6316. Of course that will require changes in QGIS. But at that
point, I don't think there are any more issues on PROJ side.
I've also submitted https://github.com/OSGeo/PROJ/pull/3587 so that PROJ
do not report a +towgs84 string for EPSG:6316 (since there are multiple
candidates, so we can't point a single good one).
Even
> Macedonia
> Dear all,
> The issue 3246 is open from July 2022.
> Main problem to be solved is separating EPSG 6316 into two separate
> CRS’s within PROJ, since it has two area extends
> (https://epsg.org/crs_6316/MGI-1901-Balkans-zone-7.html?sessionkey=pvenyf6ze2).
> Details are given in https://github.com/OSGeo/PROJ/issues/3246.
> I kindly ask You to assist in order to solve this problem.
> Kind regards,
> Bashkim.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230123/5f4abc9e/attachment.htm>
More information about the PROJ mailing list
