[PROJ] Area of usage (short) name
Javier Jimenez Shaw j1 at jimenezshaw.com
Sat Jul 22 07:20:50 PDT 2023
My use case is (I want to think) simpler.
Search for "incheon height" in epsg.org:
https://epsg.org/search/by-name?sessionkey=syx74l2mwn&searchedTerms=incheon+height
You can see "KVD1964 height", that was called before (just a few days ago)
"Incheon height" (now under Naming System "EPSG alias").
If PROJ is my access to EPSG db, I would like to be able to perform that
search somehow. I do not mind if I have to iterate (once) the whole
catalogue to create a map.
Javier
On Sat, 22 Jul 2023, 10:35 Martin Desruisseaux, <
martin.desruisseaux at geomatys.com> wrote:
> Le 21/07/2023 à 18:48, Even Rouault a écrit :
> > I don't think EPSG extent short names qualify as identifiers. They
> > might be altered between EPSG releases. Only their EPSG code is a true
> > (ie unmutable) identifier.
> True, but this is true for CRS name as well, and nevertheless ISO 19111
> defines the type of those names as MD_Identifier. I agree that this is a
> bit surprising. A possible rational is that MD_Identifier contains a
> `version` attribute. so while the identifier code alone is ambiguous and
> unstable, the (code, version) or (namespace, code, version) tuples are
> more stable.
>      Martin
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230722/558e2b71/attachment.htm>
More information about the PROJ mailing list
