[PROJ] Fixing Old Code
support at mnspoint.com support at mnspoint.com
Sun Jul 30 04:30:24 PDT 2023
Hello,
we wrote a working GeoTIFF loader a few years ago using Proj4 library.
The worts problem with GeoTIFF format is that it uses relative links to
EPSG or ESRI definitions just with a number!! AND if somebody adds new
definitions LATER the original database cannot solve them anymore!! REAL
IDIOTS!! They should have ALWAYS included the FULL definition instead of
just the "number"!! That way the GeoTIFF format would have worked
forever! Now it just works until somebody adds a new entry to the
database and some other idiot chooses to reference it in a GeoTIFF file!
But what so ever, you can try to live with this error by always using
the latest ESRI/EPSG database with your GeoTIFF loader! (So, your
GeoTIFF loader needs an ESRI/EPSG definition database to work.)
Regards: Janne
Dan Crosby kirjoitti 2023-07-26 06:19:
> One thing I tried to get working at the time, but never really did,
> was to read to geo-data from a GeoTIFF and convert
> steps I should take to get the correct projection info out of a
> GeoTIFF and convert it?
> Thanks,
> Dan
More information about the PROJ mailing list
