[PROJ] migrating to PROJ-9, missing / issues in code definitions
Even Rouault even.rouault at spatialys.com
Mon Jun 5 11:27:58 PDT 2023
Nicolas,
> 1) It seems that the entry RGTAAF07UTM42S has disappeared from the
> current IGNF dictionary
It is no longer in https://geodesie.ign.fr/contenu/fichiers/IGNF.xml
which is the source (actually we use a slightly older version of
IGNF.xml) from the records ingested into the PROJ database:
https://github.com/OSGeo/PROJ/blob/master/data/sql/ignf.sql
IGN is of course welcome to take over maintenance of the registry in
PROJ: cf https://github.com/OSGeo/PROJ/issues/2682
> 2) It seems that the geoid grid fr_ign_RAR07_bl.tif
> is missing for the definition of :
> REUN47GAUSSL
> RGR92UTM40S
> REUN47GEO
> RGR92GEO
In the new ISO191111-based paradygm (which is also more or less the one
followed by the IGNF.xml file), a grid is not part of a CRS definition.
Grids can be referenced by transformations.
e.g
bin/projinfo -s IGNF:RGR92GEO -t IGNF:REUN89
Candidate operations found: 1
Operation No. 1:
DERIVED_FROM(IGNF):TSG1160, RGR92 (RESEAU GEODESIQUE DE LA REUNION 1992)
vers IGN 1989 (REUNION), unknown accuracy, ILE DE LA REUNION, at least
one grid missing
PROJ string:
+proj=pipeline
   +step +proj=unitconvert +xy_in=deg +xy_out=rad
   +step +inv +proj=vgridshift +grids=fr_ign_RAR07_bl.tif +multiplier=1
   +step +proj=unitconvert +xy_in=rad +xy_out=deg
which directly uses the IGNF:TSG1160 transformation of IGNF.xml
> 3) It seems that the geoid grid fr_ign_1.tif
> STPM50UTM21
> RGSPM06GEO
> STPM50GEO
> RGSPM06U21
Same here:
$ bin/projinfo -s IGNF:RGSPM06GEO -t IGNF:STPM50_V
Operation No. 1:
DERIVED_FROM(IGNF):TSG1156, RGSPM06 (RESEAU GEODESIQUE DE
SAINT-PIERRE-ET-MIQUELON 2006) vers DANGER 1950
(SAINT-PIERRE-ET-MIQUELON), unknown accuracy, SAINT-PIERRE-ET-MIQUELON,
at least one grid missing
PROJ string:
+proj=pipeline
   +step +inv +proj=vgridshift +grids=fr_ign_ggspm06v1.tif +multiplier=1
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230605/1551bef6/attachment-0001.htm>
More information about the PROJ mailing list
