[PROJ] Problems with EPSG:1236 - (AGD84 to WGS 84 (2))
Even Rouault even.rouault at spatialys.com
Fri Mar 10 06:15:52 PST 2023
> EPSG:1236, AGD84 to WGS 84 (2) is missing. This has an accuracy of  5,
> same as EPSG:15789.
> Question 1:
> Is this to be considered as a bug, or is it a logical explanation? I
> have a couple of more similar examples.
You'll get it with the --show-superseded flag of projinfo:
projinfo -s AGD84 -t "WGS 84" --summary --spatial-test intersects
--show-superseded
Candidate operations found: 5
EPSG:1669, AGD84 to WGS 84 (7), 3.0 m, Australia - Queensland, South
Australia, Western Australia, federal areas offshore west of 129°E.
EPSG:1109, AGD84 to WGS 84 (1), 4.0 m, Australia - Queensland, South
EPSG:15789, AGD84 to WGS 84 (8), 5.0 m, Australia - Queensland, South
EPSG:1236, AGD84 to WGS 84 (2), 5.0 m, Australia - Queensland, South
DERIVED_FROM(EPSG):15785, AGD84 to WGS 84 (9), 2.9 m, Australia -
Queensland, South Australia, Western Australia, federal areas offshore
west of 129°E., at least one grid missing
EPSG:1236, AGD84 to WGS 84 (2) has been superseded per EPSG:1669, AGD84
to WGS 84 (7)
The supersession is recorded in the supersession table of proj.db and
also shows in the remark of EPSG:1236
     REMARK["""Higgins parameters"". Replaced by AGD84 to GDA94 (2)
(code 1280) and AGD84 to WGS 84 (7) (code 1669). Note: AGD84 officially
adopted only in Queensland, South Australia and Western Australia."]]
> Question 2:
> On the other side, I am able to get the pipeline going from 4203 to
> 4326 (AGD84 to WGS 84 (2)). by using:
> Transformer.from_pipeline(f"urn:ogc:def:coordinateOperation:EPSG::1236")
> As the API I develop delivers transformation pipelines in both
> directions, where coordinates are not always given(optional), It's
> easy to get the pipeline in both directions using TransformerGroup.
> I am considering using the urn definition + Transformer.from_pipeline
> instead, but struggle to find a way to get the reverse pipeline (from
> EPSG:4326 to EPSG:4203 (EPSG:1236)).
> Someone who can help on how this can be done?
PROJ itself has a proj_coordoperation_create_inverse() method, but it
doesn't seem to be used by pyproj. Something to potentially raise to
https://github.com/pyproj4/pyproj
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230310/69b870cf/attachment.htm>
More information about the PROJ mailing list
