[PROJ] Problems with EPSG:1236 - (AGD84 to WGS 84 (2))
Even Rouault even.rouault at spatialys.com
Wed Mar 22 05:52:43 PDT 2023
Torill,
Le 22/03/2023 à 10:01, Torill Kjøsnes Gabrielsen a écrit :
> Hi, I might ask somewhere else, but since this is related to my
> previous question, I´ll try you once more:-).
> We now have only one transformation not found, which is really good.
> Maybe not much in use, but anyway.
> It´s the concatenaded_operation "8537 - Egypt 1907 to WGS 84 (2)".
> "projinfo -s "Egypt 1907" -t "WGS 84" --summary --spatial-test
> intersects --show-superseded" gives only:
> EPSG:7697, Egypt 1907 to WGS 84 (4), 1.2 m, Egypt - onshore and offshore.
> EPSG:1148, Egypt 1907 to WGS 84 (1), 11.0 m, Egypt - onshore and offshore.
> Do you know why?
Cf fix in https://github.com/OSGeo/PROJ/pull/3673
> Thanks and regards
> Torill
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230322/0f7572f7/attachment.htm>
More information about the PROJ mailing list
