[PROJ] Lowest Astronimical Tide reference surface in Geodetic TIFF Grid
Even Rouault even.rouault at spatialys.com
Fri Mar 17 08:32:51 PDT 2023
Le 17/03/2023 à 15:44, Lesparre, Jochem a écrit :
> I wrote:
> > To prevent users to make different choices in similar use cases, the documentation should indicate what to do
> for Lowest Astronomical Tide (LAT) or other Chart Datum grids.
> ER wrote:
> > Cf https://github.com/OSGeo/PROJ/pull/3668 +
> https://github.com/OSGeo/PROJ-data/pull/97
> Thanks! This means that the Geodetic TIFF Grid for Chart Datum of
> Norway (and possibly also the one of Denmark that Kristian Evers is
> working on) wrongly use type VERTICAL_OFFSET_VERTICAL_TO_VERTICAL
> instead of VERTICAL_OFFSET_GEOGRAPHIC_TO_VERTICAL. But as that works
> too, it’s not a big deal.
> I have two questions:
>   * Are you sure about the tag “hydroid_height”? A Google search
>     (https://www.google.com/search?q=%22hydroid+height%22) gives only
>     1 relevant hit. I have no opinion on this, as it is not my
>     expertise. I’m just helping the people at our hydrographic service.
This is borrowed from the GGXF draft
(https://raw.githubusercontent.com/opengeospatial/CRS-Gridded-Geodetic-data-eXchange-Format/master/specification/GGXF%20v1-0%20OGC-22-051r2_2023-01-09.pdf).
I assume they are right, as they are much smarter people than me. They
have a slightly different naming convention "hydroidHeight" which I
modified to match our convention.
>   * Why limit the description to only predefined options? I can
>     imagine that one could want to use a reference surface that is not
>     a geoid nor a hydroid, for example an ellipsoidal DTM grid to
>     transform to/from Above Ground Level heights. So it might be
>     easier to allow any description to prevent future problems.
Well, no, we must have a predefined and limited list. Otherwise PROJ
grid interpolation code, when inspecting a GeoTIFF dataset, will not
know in which channel to find the information.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230317/7e7962ee/attachment-0001.htm>
More information about the PROJ mailing list
