[PROJ] Lowest Astronimical Tide reference surface in Geodetic TIFF Grid
Lesparre, Jochem Jochem.Lesparre at kadaster.nl
Fri Mar 17 07:44:59 PDT 2023
I wrote:
> To prevent users to make different choices in similar use cases, the documentation should indicate what to do for Lowest Astronomical Tide (LAT) or other Chart Datum grids.
ER wrote:
> Cf https://github.com/OSGeo/PROJ/pull/3668 + https://github.com/OSGeo/PROJ-data/pull/97
Thanks! This means that the Geodetic TIFF Grid for Chart Datum of Norway (and possibly also the one of Denmark that Kristian Evers is working on) wrongly use type VERTICAL_OFFSET_VERTICAL_TO_VERTICAL instead of VERTICAL_OFFSET_GEOGRAPHIC_TO_VERTICAL. But as that works too, it’s not a big deal.
I have two questions:
  *   Are you sure about the tag “hydroid_height”? A Google search (https://www.google.com/search?q=%22hydroid+height%22) gives only 1 relevant hit. I have no opinion on this, as it is not my expertise. I’m just helping the people at our hydrographic service.
  *   Why limit the description to only predefined options? I can imagine that one could want to use a reference surface that is not a geoid nor a hydroid, for example an ellipsoidal DTM grid to transform to/from Above Ground Level heights. So it might be easier to allow any description to prevent future problems.
I will probably use type VERTICAL_OFFSET_GEOGRAPHIC_TO_VERTICAL with a new description (e.g. hydroid_height) for the tif grid. But I’ll also make a gtx grid for users of PROJ versions that don’t accept the new description. I might use the gtx grid for application in EPSG for that reason. That might be easier anyway, since there are not yet tif grids in EPSG as far as I know.
Jochem
Disclaimer:
De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de geadresseerde(n).
Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of verstrekking van deze informatie aan derden is niet toegestaan.
Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden van toepassing
[https://www.kadaster.nl/algemene-leveringsvoorwaarden].
Disclaimer:
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Our general terms and conditions of delivery apply to all our products and services
[https://www.kadaster.com/general-terms-and-conditions].
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230317/bdb0b914/attachment.htm>
More information about the PROJ mailing list
