[PROJ] Lowest Astronimical Tide reference surface in Geodetic TIFF Grid
Even Rouault even.rouault at spatialys.com
Fri Mar 17 05:41:49 PDT 2023
> To prevent users to make different choices in similar use cases, the
> documentation should indicate what to do for Lowest Astronomical Tide
> (LAT) or other Chart Datum grids.
Cf https://github.com/OSGeo/PROJ/pull/3668 +
https://github.com/OSGeo/PROJ-data/pull/97
> Another question is if it is a good idea to add a Geodetic TIFF Grid
> for the transformation between the national levelling height system
> NAP and LAT of the Netherlands to EPSG? And should we add that instead
> of the ETRS89 – LAT transformation, or should we publish both in EPSG
> to shorten the number of transformation steps in PROJ?
It is really up to you, the use cases you want to solve and also
depending on if EPSG has a policy regarding this.  PROJ can
automatically chain 2 GeogCRS->VertCRS transformation where the GeogCRS
is the same (e.g doing EGM96 -> EGM2008, and I believe it can also chain
a GeogCRS->VertCRS and VertCRS->VertCRS with a pivot common VertCRS.
That said explicit concatenated transformations in the registry can help it.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230317/696a7125/attachment.htm>
More information about the PROJ mailing list
