[PROJ] Version in Zenodo
Even Rouault even.rouault at spatialys.com
Sat Mar 18 05:04:50 PDT 2023
Yes I know this is broken (for GDAL too). I tried to figure out with
zenodo help desk, but didn't manage. Here's the below exchanges (I'm not
sure I tried to do something at the last one). Happy if someone want to
take over from that.
Even
-------- Message transféré --------
Sujet : 	Re: Latest GDAL github releases not captured
Date : 	Mon, 28 Nov 2022 13:35:33 +0000
De : 	Zenodo <info at zenodo.org>
Pour : 	even.rouault <even.rouault at spatialys.com>
Dear Even,
It seems that, although you have enabled the repository you did so with
certain restrictions (at your organization level). This is the message
we are getting from GitHub:
/Although you appear to have the correct authorization credentials, the
`OSGeo` organization has enabled OAuth App access restrictions, meaning
that data access to third-parties is limited. For more information on
these restrictions, including how to enable this app, visit
https://docs.github.com/articles/restricting-access-to-your-organization-s-data//
Please let me know if there is anything else I can help you with.
Best regards,
Pablo
Zenodo Support
https://zenodo.org
*Support Zenodo* — Could we suggest you support Zenodo’s features'
development by donating to the CERN & Society Foundation? For more
information see https://zenodo.org/donate or reach out directly to our
Partnerships & Fundraising colleagues (donorcare at csf.cern.ch
<mailto:%20donorcare at csf.cern.ch>) if you have any doubts about the
donation process.
On Nov 13, 2022 at 4:36 AM even.rouault <even.rouault at spatialys.com> wrote:
    Hi Jenny,
    I followed the procedure you mention below before doing the GDAL 3.6.0
    release, and it doesn't seem to have worked as 3.5.1 is still the last
    one referenced
    Best regards,
    Even
    http://www.spatialys.com
    On Nov 4, 2022 at 7:46 AM Zenodo, Software Engineer
    <info at zenodo.org> wrote:
        Dear Even,
        It seems like the problem is caused by an expired access token
        to GitHub. Can I ask you to:
         1. Go to yourZenodo linked accounts
            <https://zenodo.org/account/settings/linkedaccounts/>.
         2. Disconnect the GitHub link
         3. Re-connect the GitHub link
        This will ensure we have a valid access token to GitHub, and
        then it should work again.
        Best regards,
        Jenny
        Zenodo Support
        https://zenodo.org
        features' development by donating to the CERN & Society
        Foundation? For more information see https://zenodo.org/donate
        or reach out directly to our Partnerships & Fundraising
        the donation process.
        On Nov 3, 2022 at 10:37 AM even.rouault
            The GDAL project (https://github.com/OSGeo/gdal) has been
            integrated in
            Zenodo since a few releases, but I notice that the 2 last
            releases,
            v3.5.2 and v3.5.3, are not captured at
            https://zenodo.org/record/6801315#.Y2P7mr6ZNH4 despite having
            corresponding github releases:
            https://github.com/OSGeo/gdal/releases/tag/v3.5.2 and
            https://github.com/OSGeo/gdal/releases/tag/v3.5.3. Do you
            know why ?
            Best regards,
            Even
Powered by UserVoice.
<http://www.uservoice.com/powered-by?utm_campaign=poweredby&utm_medium=email&utm_source=ticket&uv_company=ZENODO&uv_contact_url=zenodo.uservoice.com&uv_experience=email>
Le 18/03/2023 à 10:28, Javier Jimenez Shaw a écrit :
> Hi
> Having a look at Zenodo (after the talk from Peter Löwe in FOSSGIS -in
> German- https://pretalx.com/fossgis2023/talk/GY9XSE/ ) I am only able
> to find PROJ 9.0.1:
> https://zenodo.org/record/6646503
> Are the newer versions updated but I am not able to find them? Or is
> anything missing?
> Thanks.
> Javier
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230318/96dde802/attachment-0001.htm>
More information about the PROJ mailing list
