[PROJ] Projection with angle
Javier Jimenez Shaw j1 at jimenezshaw.com
Wed May 3 10:33:06 PDT 2023
Hi
Is there any projected CRS in PROJ, where I can set an angle with the
"north" (or something kind of equivalent) as a parameter of the projection?
The only one I found is Oblique Transverse Mercator, but I have some
numerical problems with it.
I would like to try a different one if there is any available.
I need a CRS that I can express as a PROJCRS in WKT.
Thank you,
Javier.
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230503/0f7e9945/attachment.htm>
More information about the PROJ mailing list
