[PROJ] Projection with angle
Clifford J Mugnier cjmce at lsu.edu
Wed May 3 10:35:12 PDT 2023
Try Laborde projection of Madagascar or Rosenmunde (sp?) of Switzerland
Get Outlook for iOS<https://aka.ms/o0ukef>
From: PROJ <proj-bounces at lists.osgeo.org> on behalf of Javier Jimenez Shaw <j1 at jimenezshaw.com>
Sent: Wednesday, May 3, 2023 12:33:06 PM
To: proj <PROJ at lists.osgeo.org>
Subject: [PROJ] Projection with angle
Hi
Is there any projected CRS in PROJ, where I can set an angle with the "north" (or something kind of equivalent) as a parameter of the projection?
The only one I found is Oblique Transverse Mercator, but I have some numerical problems with it.
I would like to try a different one if there is any available.
I need a CRS that I can express as a PROJCRS in WKT.
Thank you,
Javier.
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230503/a0bdd782/attachment-0001.htm>
More information about the PROJ mailing list
