[PROJ] Projection with angle
Jose Gonçalves jagoncal at gmail.com
Wed May 3 16:26:44 PDT 2023
You can use the Lambert Conformal Conic projection with a central longitude
far from the projected area. You must choose one or two standard parallels
in your area. For example, if you are projecting points (0E,35N) and
(0E,45N) and use standard parallel 40N and a central longitude of 60E:
proj +ellps=GRS80 +proj=lcc +lat_1=40 +lon_0=60
you get:
-5091780.82     1225856.77
-4398673.66     2095115.48
The projection makes a rotation of the meridian proportional to the
longitude difference from the central longitude. You can choose +lon_0
according to the rotation you want. Check the formula in some documentation
about the LCC projection, or try it empirically.
Regards
José Gonçalves
Em qua., 3 de mai. de 2023 às 18:33, Javier Jimenez Shaw <j1 at jimenezshaw.com>
escreveu:
> Hi
> Is there any projected CRS in PROJ, where I can set an angle with the
> "north" (or something kind of equivalent) as a parameter of the projection?
> The only one I found is Oblique Transverse Mercator, but I have some
> numerical problems with it.
> I would like to try a different one if there is any available.
> I need a CRS that I can express as a PROJCRS in WKT.
> Thank you,
> Javier.
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230504/e1283779/attachment.htm>
More information about the PROJ mailing list
