[PROJ] Help with transformation of GPS coordinates to TK25
support at mnspoint.com support at mnspoint.com
Tue May 16 03:25:36 PDT 2023
Hello,
don't assume anything else but that everything given has errors.
If you get some offset where it should not be, you have either
1) Wrong datum.
2) Missing datum.
3) Datum where datum should not be.
4) GPS coordinates are actually in WGS84 (but not told so). [fix your
GPS]
5) GPS coordinates are actually in some datum (but not told so). [fix
your GPS]
6) Try to google the right datum for that area and use it instead.
7) Some wrong parameter (many possibilities)
8) etc.
Mostly it is a datum error ... you are using wrong datum in some point
of the conversion or assuming something that is not true.
Usually modern GPS's give coordinates in WGS84 datum by default (so
assume that). And then convert those to TK25 datum. If the device is
preset to Germany then it most likely uses some modern datum like
Gauss-Krueger (zone 2, 3, 4 or 5) or UTM (zone 32 or 33). Then you have
to convert for example UTM 32 -> TK 25. Looks like a datum error.
Janne.
> So, _where_ is the offset coming from?  I really don't know how to
> fix this?
More information about the PROJ mailing list
