[PROJ] Unexpected no NADCON5 transformations
Javier Jimenez Shaw j1 at jimenezshaw.com
Wed May 17 06:53:39 PDT 2023
Hi devs,
I was going to get an order of magnitude of NADCON5 transformations added
in PROJ 9.2.0 (+ PROJ-data), and I found that they are not always applied.
As they are datum transformations, I would assume that they are independent
of the vertical system, but maybe I am wrong.
Going from WGS84(3D) to NAD83(2011) + NAVD88 height produces different
horizontal values than the input (what I expected)
$ echo 40 -100 0 | PROJ_NETWORK=ON ./cs2cs EPSG:4979 EPSG:6318+5703 -d 8
39.99999330 -99.99999115 25.47826194
However any other combination using 2D+vert or 3D is not changing the
horizontal coordinates.
$ echo 40 -100 0 | PROJ_NETWORK=ON ./cs2cs EPSG:4326+5773 EPSG:6319 -d 8
40.00000000 -100.00000000 -25.05249596
$ echo 40 -100 0 | PROJ_NETWORK=ON ./cs2cs EPSG:4979 EPSG:6319 -d 8
40.00000000 -100.00000000 0.00000000
$ echo 40 -100 0 | PROJ_NETWORK=ON ./cs2cs EPSG:4326+5773 EPSG:6318+5703 -d
8
40.00000000 -100.00000000 -0.49709511
Enabling the debug messages, the first case is clearly looking for the
nadcon5 grids. The other 3 are not.
Is that expected?
Thanks.
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230517/331250d0/attachment.htm>
More information about the PROJ mailing list
