[PROJ] Migrating to PROJ-9
Even Rouault even.rouault at spatialys.com
Fri May 26 12:46:00 PDT 2023
I get the expected 4070327.25 166078.93 4891298.61 result with proj
6.0.0, 7.2.1, 9.2.0 and master
There's no grid involved in this operation, just inverse LCC projection
on the RGF93 datum
I also tried to reproduce your issue if the PROJ < 6 IGNF file is found
in the PROJ resource path(s) (non nominal situation - this file is not
needed any more, and will generally lead to suboptimal results. Its
content is included in the proj.db file), but even with that I get the
expected result. So no idea why you get wrong results
Even
Le 26/05/2023 à 20:54, Nicolas Bellaiche a écrit :
> Hi all,
> I'm migrating my C++ code from PROJ4 to PROJ9 and I meet a worrying
> issue with the computation. Some of my regress tests don't pass so
> I've tested with cs2cs and gets the same difference:
> PROJ4
> echo652760.73700000 <callto:652760.73700000>7033791.24300000 43
> <callto:7033791.24300000 43>.64200000 | cs2cs +init=IGNF:LAMB93 +to
> +init=IGNF:RGF93:
> 4070327.25166078.93 4891298.61 <callto:166078.93 4891298.61>
> PROJ7 or PROJ9
> +init=IGNF:RGF93:
> 4070355.05166080.07 4891332.24 <callto:166080.07 4891332.24>
> I suspect that PROJ7 and PROJ9 don't read properly the geoid file but
> I'm not sure. Someone can help me tracking and fixing this problem?
> Thanks,
> Nicolas Bellaiche
> Institut Géographique National France
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230526/d5176f95/attachment-0001.htm>
More information about the PROJ mailing list
