[PROJ] Migrating to PROJ-9
Even Rouault even.rouault at spatialys.com
Fri May 26 12:50:27 PDT 2023
Ah, and you should avoid using the "+init=" prefix. This is a deprecated
legacy syntax that doesn't enforce axis order of the CRS definition
(without practical consequence for IGNF: CRS since they use "GIS
friendly" axis order)
To help debugging this, please provide the output of:
PROJ_DEBUG=3 projinfo -s IGNF:LAMB93 -t IGNF:RGF93 -o PROJ
On my system I get:
pj_open_lib(proj.ini): call
fopen(/home/even/proj/install-proj-master/share/proj/proj.ini) - succeeded
pj_open_lib(proj.db): call
fopen(/home/even/proj/install-proj-master/share/proj/proj.db) - succeeded
Candidate operations found: 1
Operation No. 1:
unknown id, Inverse of LAMBERT-93 + Conversion from RGF93 geographiques
(dms) to RGF93 cartesiennes geocentriques, 0 m, World
PROJ string:
+proj=pipeline
   +step +inv +proj=lcc +lat_0=46.5 +lon_0=3 +lat_1=44 +lat_2=49 +x_0=700000
         +y_0=6600000 +ellps=GRS80
   +step +proj=cart +ellps=GRS80
Le 26/05/2023 à 21:46, Even Rouault a écrit :
> Hi,
> I get the expected 4070327.25 166078.93 4891298.61 result with proj
> 6.0.0, 7.2.1, 9.2.0 and master
> There's no grid involved in this operation, just inverse LCC
> projection on the RGF93 datum
> I also tried to reproduce your issue if the PROJ < 6 IGNF file is
> found in the PROJ resource path(s) (non nominal situation - this file
> is not needed any more, and will generally lead to suboptimal results.
> Its content is included in the proj.db file), but even with that I get
> the expected result. So no idea why you get wrong results
> Even
> Le 26/05/2023 à 20:54, Nicolas Bellaiche a écrit :
>> Hi all,
>> I'm migrating my C++ code from PROJ4 to PROJ9 and I meet a worrying
>> issue with the computation. Some of my regress tests don't pass so
>> I've tested with cs2cs and gets the same difference:
>> PROJ4
>> echo652760.73700000 <callto:652760.73700000>7033791.24300000 43
>> <callto:7033791.24300000 43>.64200000 | cs2cs +init=IGNF:LAMB93 +to
>> +init=IGNF:RGF93:
>> 4070327.25166078.93 4891298.61 <callto:166078.93 4891298.61>
>> PROJ7 or PROJ9
>> +init=IGNF:RGF93:
>> 4070355.05166080.07 4891332.24 <callto:166080.07 4891332.24>
>> I suspect that PROJ7 and PROJ9 don't read properly the geoid file but
>> I'm not sure. Someone can help me tracking and fixing this problem?
>> Thanks,
>> Nicolas Bellaiche
>> Institut Géographique National France
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
> http://www.spatialys.com
> My software is free, but my time generally not.
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230526/9b9d5b24/attachment.htm>
More information about the PROJ mailing list
