[PROJ] PROJ 9.2.1RC1 & PROJ-data 1.14RC1
Kristian Evers kristianevers at gmail.com
Tue May 30 10:41:01 PDT 2023
A few minor details were reported with PROJ-data 1.14RC1 so I have prepared
and uploaded PROJ-data 1.14RC2 which fixes the problems. Link below.
https://download.osgeo.org/proj/proj-data-1.14RC2.tar.gz <https://download.osgeo.org/proj/proj-data-1.14RC2.tar.gz>
https://download.osgeo.org/proj/proj-data-1.14RC2.zip <https://download.osgeo.org/proj/proj-data-1.14RC2.zip>
Thanks to Bas for noticing the problems and supplying fixes.
Since the fixes for the PROJ-data package were minor and no issues has been reported
with the PROJ release candidate I’ll go ahead straight away and motion that both release
candidates be promoted to their final versions. I’ll start with my +1.
/Kristian
> On 24 May 2023, at 21.19, Kristian Evers <kristianevers at gmail.com> wrote:
> All,
> It’s soon time for another round of PROJ and PROJ-data releases, so in preparation for the final
> releases I have uploaded release candidates for both packages.
> Download the archives here:
> https://download.osgeo.org/proj/proj-9.2.1RC1.tar.gz
> https://download.osgeo.org/proj/proj-9.2.1RC1.zip
> https://download.osgeo.org/proj/proj-data-1.14RC1.tar.gz
> https://download.osgeo.org/proj/proj-data-1.14RC1.zip
> The PROJ release includes updates to the database contents and bug fixes. See the release notes below.
> The PROJ-data release adds the following transformations grids:
> - German Hessen grids
> - Canadian RGNC15 grids
> - Danish grids for a number of older CRS's
> Please test the release candidates and report any issues you may find with them. Either here
> on the mailing list or on GitHub.
> /Kristian
> 9.2.1 Release Notes
> Database updates
> o Add alias for old ESRI datum/CRS names of EPSG:8353
>   S_JTSK_JTSK03_Krovak_East_North (#3678)
> o Pseudo Mercator now supported with IAU CRS's (#3645)
> o Updated to EPSG 10.088 (#3731)
> Bug fixes
> o Fixed build errors with Cygwin (#3642)
> o PROJ string CRS parser: make sure that PROJ arguments of the rotated
>   string are kept in the WKT representation (#3656)
> o Fix slowness on proj_trans() when doing WGS 84 <--> NAD83 conversions (#3661)
> o vgridshift/gridshift: accept hydroid_height as valid band description (#3675)
> o WKT/PROJJSON: import/export accuracy of ConcatenatedOperation (#3676)
> o Coordinate operation factory: count identified concatenated operations as a
>   single step (#3677)
> o EngineeringCRS: make proj_create_engineering_crs() set a datum name
>   and relax isEquivalentTo() comparisons (#3685)
> o PROJJSON: fix import/export of integer parameter value, and deal with
>   interpolation CRS parameters in conversions (#3695)
> o  CMake: avoid imbalanced cmake_policy push/pop if TIFF or CURL dependency
>    cannot be found (#3697)
> o  proj_create_crs_to_crs(): restore transformation selection behaviour
>    of PROJ 9.1 when grids are missing (#3707)
> o  ESRI WKT: improve roundtrip of name and definition for UPS WGS84 CRS (#3720)
> o CRS instanciation from PROJ.4 string: set 'Unknown based on XXXX ellipsoid'
>   datum name when instanciating from known +a, +rf (#3727)
> o  cs2cs / proj_create_crs_to_crs(): fix regression with geocentric CRS (#3729)
> o  proj_trans(): set PROJ_ERR_COORD_TRANSFM_NO_OPERATION error when failing
>    in ONLY_BEST=YES mode (#3730)
> o  tinshift: raise maximum size of JSON file to 100 MB (#3736)
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230530/7d05dd46/attachment.htm>
More information about the PROJ mailing list
