[PROJ] PROJ 9.2.1RC1 & PROJ-data 1.14RC1
Alan Snow alansnow21 at gmail.com
Tue May 30 11:01:00 PDT 2023
+1. Thank you to all who contributed!
On Tue, May 30, 2023, 12:41 PM Kristian Evers <kristianevers at gmail.com>
wrote:
> A few minor details were reported with PROJ-data 1.14RC1 so I have prepared
> and uploaded PROJ-data 1.14RC2 which fixes the problems. Link below.
> https://download.osgeo.org/proj/proj-data-1.14RC2.tar.gz
> https://download.osgeo.org/proj/proj-data-1.14RC2.zip
> Thanks to Bas for noticing the problems and supplying fixes.
> Since the fixes for the PROJ-data package were minor and no issues has
> been reported
> with the PROJ release candidate I’ll go ahead straight away and motion
> that both release
> candidates be promoted to their final versions. I’ll start with my +1.
> /Kristian
> On 24 May 2023, at 21.19, Kristian Evers <kristianevers at gmail.com> wrote:
> All,
> It’s soon time for another round of PROJ and PROJ-data releases, so in
> preparation for the final
> releases I have uploaded release candidates for both packages.
> Download the archives here:
> https://download.osgeo.org/proj/proj-9.2.1RC1.tar.gz
> https://download.osgeo.org/proj/proj-9.2.1RC1.zip
> https://download.osgeo.org/proj/proj-data-1.14RC1.tar.gz
> https://download.osgeo.org/proj/proj-data-1.14RC1.zip
> The PROJ release includes updates to the database contents and bug fixes.
> See the release notes below.
> The PROJ-data release adds the following transformations grids:
> - German Hessen grids
> - Canadian RGNC15 grids
> - Danish grids for a number of older CRS's
> Please test the release candidates and report any issues you may find with
> them. Either here
> on the mailing list or on GitHub.
> /Kristian
> 9.2.1 Release Notes
> Database updates
> o Add alias for old ESRI datum/CRS names of EPSG:8353
>   S_JTSK_JTSK03_Krovak_East_North (#3678)
> o Pseudo Mercator now supported with IAU CRS's (#3645)
> o Updated to EPSG 10.088 (#3731)
> Bug fixes
> o Fixed build errors with Cygwin (#3642)
> o PROJ string CRS parser: make sure that PROJ arguments of the rotated
>   string are kept in the WKT representation (#3656)
> o Fix slowness on proj_trans() when doing WGS 84 <--> NAD83 conversions
> (#3661)
> o vgridshift/gridshift: accept hydroid_height as valid band description
> (#3675)
> o WKT/PROJJSON: import/export accuracy of ConcatenatedOperation (#3676)
> o Coordinate operation factory: count identified concatenated operations
> as a
>   single step (#3677)
> o EngineeringCRS: make proj_create_engineering_crs() set a datum name
>   and relax isEquivalentTo() comparisons (#3685)
> o PROJJSON: fix import/export of integer parameter value, and deal with
>   interpolation CRS parameters in conversions (#3695)
> o  CMake: avoid imbalanced cmake_policy push/pop if TIFF or CURL dependency
>    cannot be found (#3697)
> o  proj_create_crs_to_crs(): restore transformation selection behaviour
>    of PROJ 9.1 when grids are missing (#3707)
> o  ESRI WKT: improve roundtrip of name and definition for UPS WGS84 CRS
> (#3720)
> o CRS instanciation from PROJ.4 string: set 'Unknown based on XXXX
> ellipsoid'
>   datum name when instanciating from known +a, +rf (#3727)
> o  cs2cs / proj_create_crs_to_crs(): fix regression with geocentric CRS
> (#3729)
> o  proj_trans(): set PROJ_ERR_COORD_TRANSFM_NO_OPERATION error when failing
>    in ONLY_BEST=YES mode (#3730)
> o  tinshift: raise maximum size of JSON file to 100 MB (#3736)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230530/deadad5e/attachment.htm>
More information about the PROJ mailing list
