[PROJ] PROJ 9.2.1RC1 & PROJ-data 1.14RC1
Even Rouault even.rouault at spatialys.com
Tue May 30 11:40:38 PDT 2023
+1 Even
Le 30/05/2023 à 19:41, Kristian Evers a écrit :
> A few minor details were reported with PROJ-data 1.14RC1 so I have
> prepared
> and uploaded PROJ-data 1.14RC2 which fixes the problems. Link below.
> https://download.osgeo.org/proj/proj-data-1.14RC2.tar.gz
> https://download.osgeo.org/proj/proj-data-1.14RC2.zip
> Thanks to Bas for noticing the problems and supplying fixes.
> Since the fixes for the PROJ-data package were minor and no issues has
> been reported
> with the PROJ release candidate I’ll go ahead straight away and motion
> that both release
> candidates be promoted to their final versions. I’ll start with my +1.
> /Kristian
>> On 24 May 2023, at 21.19, Kristian Evers <kristianevers at gmail.com> wrote:
>> All,
>> It’s soon time for another round of PROJ and PROJ-data releases, so
>> in preparation for the final
>> releases I have uploaded release candidates for both packages.
>> Download the archives here:
>> https://download.osgeo.org/proj/proj-9.2.1RC1.tar.gz
>> https://download.osgeo.org/proj/proj-9.2.1RC1.zip
>> https://download.osgeo.org/proj/proj-data-1.14RC1.tar.gz
>> https://download.osgeo.org/proj/proj-data-1.14RC1.zip
>> The PROJ release includes updates to the database contents and bug
>> fixes. See the release notes below.
>> The PROJ-data release adds the following transformations grids:
>> - German Hessen grids
>> - Canadian RGNC15 grids
>> - Danish grids for a number of older CRS's
>> Please test the release candidates and report any issues you may find
>> with them. Either here
>> on the mailing list or on GitHub.
>> /Kristian
>> 9.2.1 Release Notes
>> Database updates
>> o Add alias for old ESRI datum/CRS names of EPSG:8353
>>   S_JTSK_JTSK03_Krovak_East_North (#3678)
>> o Pseudo Mercator now supported with IAU CRS's (#3645)
>> o Updated to EPSG 10.088 (#3731)
>> Bug fixes
>> o Fixed build errors with Cygwin (#3642)
>> o PROJ string CRS parser: make sure that PROJ arguments of the rotated
>>   string are kept in the WKT representation (#3656)
>> o Fix slowness on proj_trans() when doing WGS 84 <--> NAD83
>> conversions (#3661)
>> o vgridshift/gridshift: accept hydroid_height as valid band
>> description (#3675)
>> o WKT/PROJJSON: import/export accuracy of ConcatenatedOperation (#3676)
>> o Coordinate operation factory: count identified concatenated
>> operations as a
>>   single step (#3677)
>> o EngineeringCRS: make proj_create_engineering_crs() set a datum name
>>   and relax isEquivalentTo() comparisons (#3685)
>> o PROJJSON: fix import/export of integer parameter value, and deal with
>>   interpolation CRS parameters in conversions (#3695)
>> o  CMake: avoid imbalanced cmake_policy push/pop if TIFF or CURL
>> dependency
>>    cannot be found (#3697)
>> o  proj_create_crs_to_crs(): restore transformation selection behaviour
>>    of PROJ 9.1 when grids are missing (#3707)
>> o  ESRI WKT: improve roundtrip of name and definition for UPS WGS84
>> CRS (#3720)
>> o CRS instanciation from PROJ.4 string: set 'Unknown based on XXXX
>> ellipsoid'
>>   datum name when instanciating from known +a, +rf (#3727)
>> o  cs2cs / proj_create_crs_to_crs(): fix regression with geocentric
>> CRS (#3729)
>> o  proj_trans(): set PROJ_ERR_COORD_TRANSFM_NO_OPERATION error when
>> failing
>>    in ONLY_BEST=YES mode (#3730)
>> o  tinshift: raise maximum size of JSON file to 100 MB (#3736)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230530/96e84885/attachment.htm>
More information about the PROJ mailing list
