[PROJ] Migrating to PROJ-9
Even Rouault even.rouault at spatialys.com
Tue May 30 10:48:17 PDT 2023
Le 30/05/2023 à 19:24, Nicolas Bellaiche a écrit :
> Ok, i kind of fixed my issue even if that's not all very clear to me.
> One of the things that I can't understand is that outdated "+init="
> For instance if I try to use
> echo 2d20\'11.5\"E46d47\'59.775\"N |./bin/projIGNF:LAMBE -Swithout the
> +init= syntaxI get
> proj_create: unrecognized format / unknown name
> Rel. 9.1.1, December 1st, 2022
> <proj>:
> projection initialization failure
> cause: Invalid PROJ string syntax
> program abnormally terminated
> Is it normal?
Maybe? the old proj utility works with coordinate operations, actually
only map projections, but not CRS definitions. In PROJ 4.x era, there
was no such distinction. IGNF:LAMBE is a CRS definition now. Furthermore
the proj utility has not been updated to resolve objects by code/names.
(with the +init= prefix, proj errors out with "can't initialize
operations that take non-angular input coordinates" for me. likely some
mismatch between radian vs degree input expectations). I presume it
could be enhanced to work with projected CRS definitions, although it is
not totally clear to me what should be the expectations regarding
input/output axis order.
Even
> Sincerely,
> N.B.
> *De: *"Even Rouault" <even.rouault at spatialys.com>
> *À: *"Nicolas Bellaiche" <nicolas.bellaiche at ign.fr>
> *Cc: *"proj" <proj at lists.osgeo.org>
> *Envoyé: *Mardi 30 Mai 2023 14:43:03
> *Objet: *Re: [PROJ] Migrating to PROJ-9
> Weird indeed:
> and what about trying directly the pipeline with cct :
> echo 652760.73700000 7033791.24300000 43.64200000 | cct +proj=pipeline
> +step +inv +proj=lcc +lat_0=46.5 +lon_0=3 +lat_1=44 +lat_2=49
> +x_0=700000 +y_0=6600000 +ellps=GRS80 +step +proj=cart +ellps=GRS80
> you should get:
>  4070327.2514    166078.9321  4891298.6149           inf
> Le 30/05/2023 à 14:35, Nicolas Bellaiche a écrit :
>     Bonjour M. Rouault,
>     Voilà ce que j'obtiens:
>     *PROJ9:*
>     *Release % PROJ_DEBUG=3 projinfo -s IGNF:LAMB93 -t IGNF:RGF93 -o PROJ*
>     pj_open_lib(proj.ini): call
>     fopen(/Users/nbellaiche/dev/sd-externs/macosx-clang/proj-9.1.1/nad/proj.ini)
>     - succeeded
>     pj_open_lib(proj.db): call
>     fopen(/Users/nbellaiche/dev/sd-externs/macosx-clang/proj-9.1.1/nad/proj.db)
>     - succeeded
>     Candidate operations found: 1
>     Operation No. 1:
>     unknown id, Inverse of LAMBERT-93 + Conversion from RGF93
>     geographiques (dms) to RGF93 cartesiennes geocentriques, 0 m, World
>     PROJ string:
>     +proj=pipeline
>     +x_0=700000
>     * Release % echo 652760.73700000 7033791.24300000 43.64200000 |
>     cs2cs +init=IGNF:LAMB93 +to +init=IGNF:RGF93*
>     4070355.05166080.07 4891332.24
>     * Release % echo $PROJ_DATA*
>     * Release % echo $PROJ_LIB*
>     je ne vois pas de différence. Je n'ai pas le début d'une idée de
>     comment identifier le problème...
>     N.
>     <mailto:even.rouault at spatialys.com>
>     *À: *"proj" <proj at lists.osgeo.org> <mailto:proj at lists.osgeo.org>
>     *Envoyé: *Vendredi 26 Mai 2023 21:50:27
>     Ah, and you should avoid using the "+init=" prefix. This is a
>     deprecated legacy syntax that doesn't enforce axis order of the
>     CRS definition (without practical consequence for IGNF: CRS since
>     they use "GIS friendly" axis order)
>     To help debugging this, please provide the output of:
>     On my system I get:
>     fopen(/home/even/proj/install-proj-master/share/proj/proj.ini) -
>     succeeded
>     fopen(/home/even/proj/install-proj-master/share/proj/proj.db) -
>     succeeded
>     Operation No. 1:
>     PROJ string:
>     +proj=pipeline
>     +x_0=700000
>     Le 26/05/2023 à 21:46, Even Rouault a écrit :
>         Hi,
>         I get the expected 4070327.25 166078.93 4891298.61 result with
>         proj 6.0.0, 7.2.1, 9.2.0 and master
>         There's no grid involved in this operation, just inverse LCC
>         projection on the RGF93 datum
>         I also tried to reproduce your issue if the PROJ < 6 IGNF file
>         is found in the PROJ resource path(s) (non nominal situation -
>         this file is not needed any more, and will generally lead to
>         suboptimal results. Its content is included in the proj.db
>         file), but even with that I get the expected result. So no
>         idea why you get wrong results
>         Even
>         Le 26/05/2023 à 20:54, Nicolas Bellaiche a écrit :
>             Hi all,
>             I'm migrating my C++ code from PROJ4 to PROJ9 and I meet a
>             worrying issue with the computation. Some of my regress
>             tests don't pass so I've tested with cs2cs and gets the
>             same difference:
>             PROJ4
>             echo652760.737000007033791.24300000 43.64200000 | cs2cs
>             +init=IGNF:LAMB93 +to +init=IGNF:RGF93:
>             4070327.25166078.93 4891298.61
>             PROJ7 or PROJ9
>             I suspect that PROJ7 and PROJ9 don't read properly the
>             geoid file but I'm not sure. Someone can help me tracking
>             and fixing this problem?
>             Thanks,
>             Nicolas Bellaiche
>             Institut Géographique National France
>             _______________________________________________
>             PROJ mailing list
>             PROJ at lists.osgeo.org
>             https://lists.osgeo.org/mailman/listinfo/proj
>         http://www.spatialys.com
>         My software is free, but my time generally not.
>         PROJ mailing list
>     PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230530/5eee42ef/attachment-0001.htm>
More information about the PROJ mailing list
