[PROJ] PROJ 9.3.1RC1 & PROJ-data 1.16RC1
Even Rouault even.rouault at spatialys.com
Sun Nov 26 11:01:41 PST 2023
Hi Kristian,
The archives looks good to me.
Even
Le 26/11/2023 à 17:48, Kristian Evers via PROJ a écrit :
> All,
> It’s time for another round of releases, so in preparation for the final packages I have uploaded
>   release candidates for PROJ and PROJ-data. Download the archives here:
> https://download.osgeo.org/proj/proj-9.3.1RC1.tar.gz
> https://download.osgeo.org/proj/proj-9.3.1RC1.zip
> https://download.osgeo.org/proj/proj-data-1.16RC1.tar.gz
> https://download.osgeo.org/proj/proj-data-1.16RC1.zip
> The PROJ release includes updates to the database contents and bug fixes. See the release notes below.
> The PROJ-data release adds the German geoid model GCG2016.
> Please test the release candidates and report any issues you may find with them. Either here
> on the mailing list or on GitHub.
> /Kristian
> 9.3.1 Release Notes
>   Updates
>   o Update to EPSG 10.098 (#3968)
>   o Update ESRI objects to v3.2.0 (#3944)
>   Bug fixes
>   o ITRF2008: fix wrong sign for 'dry' parameter of EURA and EURA_T  (#3870)
>   o Fix build error with MSVC 2019 in /std:c++20 on NN_NO_CHECK() (#3872)
>   o  ESRI WKT import: normalize GCS_unknown to unknown and D_unknown to unknown (#3874)
>   o CoordinateOperationFactory: deal with CompoundToCompound with a horizontal similarity
>     transformation and a ballpark vertical (#3881)
>   o Ellipsoid::_isEquivalentTo(): fix so that an ellipsoid of semi-major axis A (and
>     non-zero inv flattening) isn't equivalent to a sphere of radius A (#3882)
>   o isEquivalentTo(): make a datum name 'unknown' equivalent to another one (#3883)
>   o cs2cs: fix handling of input coordinates in grad (#3886)
>   o Make setargv.obj available on Universal Windows Platform (#3891)
>   o Allow opening proj.db with a URI (#3892)
>   o createOperations(): fix GeogCRS 3D with TOWGS84 to geocentric CRS (#3915)
>   o Fix test suite so that it can pass with ENABLE_TIFF=OFF (#3916)
>   o GeographicBoundingBox::intersects(): avoid infinite recursion and stack overflow
>     on invalid bounding boxes (#3919)
>   o Fix importing '+proj=topocentric ... +type=crs' by using a geocentric CRS as
>     the base CRS (#3924)
>   o Allow LOCAL_CS with 3 axes (#3928)
>   o WKT1 parser: in non-strict mode, accept missing UNIT[] in GEOGCS, GEOCCS,
>     PROJCS and VERT_CS elements (#3933)
>   o createOperations(): fix issue with a obscure case involving CompoundCRS of
>     unknown horizontal datum + boundCRS of vertical (#3934)
>   o createOperations(): fix bad PROJ pipeline when converting between Geog3D
>     with non-metre height to CompoundCRS (#3943)
>   o createOperations(): Fix possible null dereference on invalid WKT input (#3946)
>   o proj_factor: fix when input is a compound CRS of a projected CRS (#3950)
>   o pj_get_suggested_operation(): tune it to give correct result for RGAF09 to
>     RRAF 1991 / UTM zone 20N + Guadeloupe 1988 height transformation (#3954)
>   o Move static NameSpace::GLOBAL definition in static.cpp to avoid
>    'static initialization fiasco' (#3956)
>   o horner: allow arbitrary input type of coordinate (#3961)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
More information about the PROJ mailing list
