[PROJ] PROJ 9.3.1RC1 & PROJ-data 1.16RC1
Kristian Evers kristianevers at gmail.com
Thu Nov 30 21:53:35 PST 2023
PSC members,
No issues have been reported with the two release candidates so I motion that they
are promoted to final releases.
I’ll start with my +1.
/Kristian
> On 26 Nov 2023, at 20.01, Even Rouault <even.rouault at spatialys.com> wrote:
> Hi Kristian,
> The archives looks good to me.
> Even
> Le 26/11/2023 à 17:48, Kristian Evers via PROJ a écrit :
>> All,
>> It’s time for another round of releases, so in preparation for the final packages I have uploaded
>>  release candidates for PROJ and PROJ-data. Download the archives here:
>> https://download.osgeo.org/proj/proj-9.3.1RC1.tar.gz
>> https://download.osgeo.org/proj/proj-9.3.1RC1.zip
>>   https://download.osgeo.org/proj/proj-data-1.16RC1.tar.gz
>> https://download.osgeo.org/proj/proj-data-1.16RC1.zip
>> The PROJ release includes updates to the database contents and bug fixes. See the release notes below.
>> The PROJ-data release adds the German geoid model GCG2016.
>> Please test the release candidates and report any issues you may find with them. Either here
>> on the mailing list or on GitHub.
>> /Kristian
>> 9.3.1 Release Notes
>>  Updates
>>  o Update to EPSG 10.098 (#3968)
>>  o Update ESRI objects to v3.2.0 (#3944)
>>  Bug fixes
>>  o ITRF2008: fix wrong sign for 'dry' parameter of EURA and EURA_T  (#3870)
>>  o Fix build error with MSVC 2019 in /std:c++20 on NN_NO_CHECK() (#3872)
>>  o  ESRI WKT import: normalize GCS_unknown to unknown and D_unknown to unknown (#3874)
>>  o CoordinateOperationFactory: deal with CompoundToCompound with a horizontal similarity
>>    transformation and a ballpark vertical (#3881)
>>  o Ellipsoid::_isEquivalentTo(): fix so that an ellipsoid of semi-major axis A (and
>>    non-zero inv flattening) isn't equivalent to a sphere of radius A (#3882)
>>  o isEquivalentTo(): make a datum name 'unknown' equivalent to another one (#3883)
>>  o cs2cs: fix handling of input coordinates in grad (#3886)
>>  o Make setargv.obj available on Universal Windows Platform (#3891)
>>  o Allow opening proj.db with a URI (#3892)
>>  o createOperations(): fix GeogCRS 3D with TOWGS84 to geocentric CRS (#3915)
>>  o Fix test suite so that it can pass with ENABLE_TIFF=OFF (#3916)
>>  o GeographicBoundingBox::intersects(): avoid infinite recursion and stack overflow
>>    on invalid bounding boxes (#3919)
>>  o Fix importing '+proj=topocentric ... +type=crs' by using a geocentric CRS as
>>    the base CRS (#3924)
>>  o Allow LOCAL_CS with 3 axes (#3928)
>>  o WKT1 parser: in non-strict mode, accept missing UNIT[] in GEOGCS, GEOCCS,
>>    PROJCS and VERT_CS elements (#3933)
>>  o createOperations(): fix issue with a obscure case involving CompoundCRS of
>>    unknown horizontal datum + boundCRS of vertical (#3934)
>>  o createOperations(): fix bad PROJ pipeline when converting between Geog3D
>>    with non-metre height to CompoundCRS (#3943)
>>  o createOperations(): Fix possible null dereference on invalid WKT input (#3946)
>>  o proj_factor: fix when input is a compound CRS of a projected CRS (#3950)
>>  o pj_get_suggested_operation(): tune it to give correct result for RGAF09 to
>>    RRAF 1991 / UTM zone 20N + Guadeloupe 1988 height transformation (#3954)
>>  o Move static NameSpace::GLOBAL definition in static.cpp to avoid
>>   'static initialization fiasco' (#3956)
>>  o horner: allow arbitrary input type of coordinate (#3961)
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
> http://www.spatialys.com
> My software is free, but my time generally not.
More information about the PROJ mailing list
