[PROJ] PROJ 9.3.0RC1 & PROJ-data 1.15RC1
Thomas Knudsen knudsen.thomas at gmail.com
Fri Sep 1 01:38:46 PDT 2023
+1 Thomas
Den fre. 1. sep. 2023 kl. 07.35 skrev Charles Karney <
charles.karney at gmail.com>:
> +1
>   --Charles
> On Fri, Sep 1, 2023 at 6:16 AM Kristian Evers <kristianevers at gmail.com>
> wrote:
> > PCS members,
> > No issues have been reported with PROJ 9.3.0RC2 or PROJ-data 1.15RC1, so
> I
> > hereby motion that they are promoted to their final releases.
> > I’ll start with my +1.
> > /Kristian
> > On 30 Aug 2023, at 20.23, Kristian Evers <kristianevers at gmail.com>
> wrote:
> > All,
> > A few minor issues were found in PROJ-9.3.0RC1. They have been fixed and
> a second release candidate
> > is now available. Download it here:
> > https://download.osgeo.org/proj/proj-9.3.0RC2.tar.gz
> > https://download.osgeo.org/proj/proj-9.3.0RC2.zip
> > /Kristian
> > On 27 Aug 2023, at 21.03, Kristian Evers <kristianevers at gmail.com>
> wrote:
> > All,
> > in preparation for a new round of PROJ and PROJ-data release I have
> uploaded release candidates for both packages.
> > Download the archives here:
> > https://download.osgeo.org/proj/proj-9.3.0RC1.tar.gz
> > https://download.osgeo.org/proj/proj-9.3.0RC1.zip
> > https://download.osgeo.org/proj/proj-data-1.15RC1.tar.gz
> > https://download.osgeo.org/proj/proj-data-1.15RC1.zip
> > The PROJ release includes various updates and bug fixes. See the release
> notes below.
> > The PROJ-data release adds the following transformations grids:
> > - Argentinian GEOIDE-Ar16geoid model
> > - Polish geoid model PL-geoid2021
> > - Canadian HT2_1997, HT2_1997_CGG2013a, HT2_2002v70 and
> HT2_2002v70_CGG2013a vertical grids
> > Please test the release candidates and report any issues you may find
> with them.
> > Either here on the mailing list or on GitHub.
> > /Kristian
> > 9.3.0 Release Notes
> > Updates
> > o Add C++ API to transform coordinate (#3705)
> > o CMake: add PROJ_DB_CACHE_DIR (#3711)
> > o Implement EPSG:1026 Mercator (Spherical) method (#3741)
> > o CMake: remove useless cross-compiling related checks (#3747)
> > o Add mapping of Equidistant Conic to new EPSG:1119 method (#3812)
> > o Implement proposal001 from Planetary DWG from OGC (#3816)
> > o Add option in proj CLI to use a CRS (#3825)
> > o proj_factors(): make it work with projected CRS with non-metre unit
> and/or
> >   northing/easting axis order (#3826)
> > o PROJ_DEBUG: make ON an alias of 2, and OFF of 1 (#3835)
> > o Database: update to EPSG 10.094 (#3847)
> > Bug fixes
> > o GeographicBoundingBox::intersection(): avoid infinite recursion and
> stack
> >   overflow on invalid bounding boxes (#3748)
> > o Various fixes related to concatenated operations (#3820)
> > o Projected CRS identification: fix crash when the base CRS is a
> >   non-geographic geodetic CRS (#3830)
> > o Avoid C++ exceptions to be thrown (and caught) when parsing strings
> >   like '+proj=longlat +datum=WGS84 +type=crs' (#3834)
> > o BUG: Handle prefix whitespace when guessing WKT dialiect (#3841)
> > o proj_alter_id(): make it replace an existing ID instead
> >   of appending a new one (#3846)
> > o bonne: fix inverse map projection computations when lat_1 < 0 (#3849)
> > o WKT1 ESRI import/export: fix GCS name for EPSG:8353
> S-JTSK_[JTSK03]_Krovak_East_North (#3851)
> > PROJ mailing list
> > PROJ at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/proj
> Charles Karney <karney at alum.mit.edu>
> 702 Prospect Ave
> Princeton, NJ 08540
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230901/1e5ba0df/attachment-0001.htm>
More information about the PROJ mailing list
