[PROJ] PROJ 9.3.0RC1 & PROJ-data 1.15RC1
Kristian Evers kreve at sdfi.dk
Fri Sep 1 02:07:33 PDT 2023
With +1’s from myself, Charles and Thomas I declare the motion passed.
Expect a release announcement later today.
/Kristian
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Thomas Knudsen
Sent: 1. september 2023 10:39
To: Kristian Evers <kristianevers at gmail.com>; PROJ <proj at lists.osgeo.org>
Subject: Re: [PROJ] PROJ 9.3.0RC1 & PROJ-data 1.15RC1
+1 Thomas
Den fre. 1. sep. 2023 kl. 07.35 skrev Charles Karney <charles.karney at gmail.com<mailto:charles.karney at gmail.com>>:
+1
  --Charles
On Fri, Sep 1, 2023 at 6:16 AM Kristian Evers <kristianevers at gmail.com<mailto:kristianevers at gmail.com>> wrote:
> PCS members,
> No issues have been reported with PROJ 9.3.0RC2 or PROJ-data 1.15RC1, so I
> hereby motion that they are promoted to their final releases.
> I’ll start with my +1.
> /Kristian
> On 30 Aug 2023, at 20.23, Kristian Evers <kristianevers at gmail.com<mailto:kristianevers at gmail.com>> wrote:
> All,
> A few minor issues were found in PROJ-9.3.0RC1. They have been fixed and a second release candidate
> is now available. Download it here:
> https://download.osgeo.org/proj/proj-9.3.0RC2.tar.gz
> https://download.osgeo.org/proj/proj-9.3.0RC2.zip
> /Kristian
> On 27 Aug 2023, at 21.03, Kristian Evers <kristianevers at gmail.com<mailto:kristianevers at gmail.com>> wrote:
> All,
> in preparation for a new round of PROJ and PROJ-data release I have uploaded release candidates for both packages.
> Download the archives here:
> https://download.osgeo.org/proj/proj-9.3.0RC1.tar.gz
> https://download.osgeo.org/proj/proj-9.3.0RC1.zip
> https://download.osgeo.org/proj/proj-data-1.15RC1.tar.gz
> https://download.osgeo.org/proj/proj-data-1.15RC1.zip
> The PROJ release includes various updates and bug fixes. See the release notes below.
> The PROJ-data release adds the following transformations grids:
> - Argentinian GEOIDE-Ar16geoid model
> - Polish geoid model PL-geoid2021
> - Canadian HT2_1997, HT2_1997_CGG2013a, HT2_2002v70 and HT2_2002v70_CGG2013a vertical grids
> Please test the release candidates and report any issues you may find with them.
> Either here on the mailing list or on GitHub.
> /Kristian
> 9.3.0 Release Notes
> Updates
> o Add C++ API to transform coordinate (#3705)
> o CMake: add PROJ_DB_CACHE_DIR (#3711)
> o Implement EPSG:1026 Mercator (Spherical) method (#3741)
> o CMake: remove useless cross-compiling related checks (#3747)
> o Add mapping of Equidistant Conic to new EPSG:1119 method (#3812)
> o Implement proposal001 from Planetary DWG from OGC (#3816)
> o Add option in proj CLI to use a CRS (#3825)
> o proj_factors(): make it work with projected CRS with non-metre unit and/or
>   northing/easting axis order (#3826)
> o PROJ_DEBUG: make ON an alias of 2, and OFF of 1 (#3835)
> o Database: update to EPSG 10.094 (#3847)
> Bug fixes
> o GeographicBoundingBox::intersection(): avoid infinite recursion and stack
>   overflow on invalid bounding boxes (#3748)
> o Various fixes related to concatenated operations (#3820)
> o Projected CRS identification: fix crash when the base CRS is a
>   non-geographic geodetic CRS (#3830)
> o Avoid C++ exceptions to be thrown (and caught) when parsing strings
>   like '+proj=longlat +datum=WGS84 +type=crs' (#3834)
> o BUG: Handle prefix whitespace when guessing WKT dialiect (#3841)
> o proj_alter_id(): make it replace an existing ID instead
>   of appending a new one (#3846)
> o bonne: fix inverse map projection computations when lat_1 < 0 (#3849)
> o WKT1 ESRI import/export: fix GCS name for EPSG:8353 S-JTSK_[JTSK03]_Krovak_East_North (#3851)
> PROJ mailing list
> PROJ at lists.osgeo.org<mailto:PROJ at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/proj
Charles Karney <karney at alum.mit.edu<mailto:karney at alum.mit.edu>>
702 Prospect Ave
Princeton, NJ 08540
PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230901/41e0f0e8/attachment.htm>
More information about the PROJ mailing list
