[PROJ] PROJ 9.3.0RC1 & PROJ-data 1.15RC1
Even Rouault even.rouault at spatialys.com
Fri Sep 1 02:30:24 PDT 2023
+1 Even
Le 01/09/2023 à 07:16, Kristian Evers a écrit :
> PCS members,
> No issues have been reported with PROJ 9.3.0RC2 or PROJ-data 1.15RC1, so I
> hereby motion that they are promoted to their final releases.
> I’ll start with my +1.
> /Kristian
>> On 30 Aug 2023, at 20.23, Kristian Evers <kristianevers at gmail.com> wrote:
>> All,
>> A few minor issues were found in PROJ-9.3.0RC1. They have been fixed
>> and a second release candidate
>> is now available. Download it here:
>> https://download.osgeo.org/proj/proj-9.3.0RC2.tar.gz
>> https://download.osgeo.org/proj/proj-9.3.0RC2.zip
>> /Kristian
>>> On 27 Aug 2023, at 21.03, Kristian Evers <kristianevers at gmail.com>
>>> wrote:
>>> All,
>>> in preparation for a new round of PROJ and PROJ-data release I have
>>> uploaded release candidates for both packages.
>>> Download the archives here:
>>> https://download.osgeo.org/proj/proj-9.3.0RC1.tar.gz
>>> https://download.osgeo.org/proj/proj-9.3.0RC1.zip
>>> https://download.osgeo.org/proj/proj-data-1.15RC1.tar.gz
>>> https://download.osgeo.org/proj/proj-data-1.15RC1.zip
>>> The PROJ release includes various updates and bug fixes. See the
>>> release notes below.
>>> The PROJ-data release adds the following transformations grids:
>>> - Argentinian GEOIDE-Ar16geoid model
>>> - Polish geoid model PL-geoid2021
>>> - Canadian HT2_1997, HT2_1997_CGG2013a, HT2_2002v70 and
>>> HT2_2002v70_CGG2013a vertical grids
>>> Please test the release candidates and report any issues you may
>>> find with them.
>>> Either here on the mailing list or on GitHub.
>>> /Kristian
>>> 9.3.0 Release Notes
>>> Updates
>>> o Add C++ API to transform coordinate (#3705)
>>> o CMake: add PROJ_DB_CACHE_DIR (#3711)
>>> o Implement EPSG:1026 Mercator (Spherical) method (#3741)
>>> o CMake: remove useless cross-compiling related checks (#3747)
>>> o Add mapping of Equidistant Conic to new EPSG:1119 method (#3812)
>>> o Implement proposal001 from Planetary DWG from OGC (#3816)
>>> o Add option in proj CLI to use a CRS (#3825)
>>> o proj_factors(): make it work with projected CRS with non-metre
>>> unit and/or
>>>   northing/easting axis order (#3826)
>>> o PROJ_DEBUG: make ON an alias of 2, and OFF of 1 (#3835)
>>> o Database: update to EPSG 10.094 (#3847)
>>> Bug fixes
>>> o GeographicBoundingBox::intersection(): avoid infinite recursion
>>> and stack
>>>   overflow on invalid bounding boxes (#3748)
>>> o Various fixes related to concatenated operations (#3820)
>>> o Projected CRS identification: fix crash when the base CRS is a
>>>   non-geographic geodetic CRS (#3830)
>>> o Avoid C++ exceptions to be thrown (and caught) when parsing strings
>>>   like '+proj=longlat +datum=WGS84 +type=crs' (#3834)
>>> o BUG: Handle prefix whitespace when guessing WKT dialiect (#3841)
>>> o proj_alter_id(): make it replace an existing ID instead
>>>   of appending a new one (#3846)
>>> o bonne: fix inverse map projection computations when lat_1 < 0 (#3849)
>>> o WKT1 ESRI import/export: fix GCS name for EPSG:8353
>>> S-JTSK_[JTSK03]_Krovak_East_North (#3851)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230901/5297d364/attachment-0001.htm>
More information about the PROJ mailing list
