[PROJ] PROJ 9.3.0 & PROJ-data 1.15
Kristian Evers kreve at sdfi.dk
Fri Sep 1 05:10:54 PDT 2023
I'm happy to announce the release of PROJ 9.3.0 and PROJ-data 1.15!
The PROJ release includes a number of updates to the both functionality and
the database contents, as well as a number of bug fixes. See the release notes
below.
The PROJ-data release includes the following updates:
- Argentinian GEOIDE-Ar16 geoid model
- Polish PL-geoid2021 geoid model
- Canadian HT2_1997, HT2_1997_CGG2013a, HT2_2002v70 and HT2_2002v70_CGG2013a vertical grids
Download the archives here:
http://download.osgeo.org/proj/proj-9.3.0.tar.gz
http://download.osgeo.org/proj/proj-9.3.0.zip
http://download.osgeo.org/proj/proj-data-1.15.tar.gz
http://download.osgeo.org/proj/proj-data-1.15.zip
/Kristian
9.3.0 Release Notes
 Updates
 o Add C++ API to transform coordinate (#3705)
 o CMake: add PROJ_DB_CACHE_DIR (#3711)
 o Implement EPSG:1026 Mercator (Spherical) method (#3741)
 o CMake: remove useless cross-compiling related checks (#3747)
 o Add mapping of Equidistant Conic to new EPSG:1119 method (#3812)
 o Implement proposal001 from Planetary DWG from OGC (#3816)
 o Add option in proj CLI to use a CRS (#3825)
 o proj_factors(): make it work with projected CRS with non-metre unit and/or
   northing/easting axis order (#3826)
 o PROJ_DEBUG: make ON an alias of 2, and OFF of 1 (#3835)
 o Database: update to EPSG 10.094 (#3847)
 Bug fixes
 o GeographicBoundingBox::intersection(): avoid infinite recursion and stack
   overflow on invalid bounding boxes (#3748)
 o Various fixes related to concatenated operations (#3820)
 o Projected CRS identification: fix crash when the base CRS is a
   non-geographic geodetic CRS (#3830)
 o Avoid C++ exceptions to be thrown (and caught) when parsing strings
   like '+proj=longlat +datum=WGS84 +type=crs' (#3834)
 o BUG: Handle prefix whitespace when guessing WKT dialiect (#3841)
 o proj_alter_id(): make it replace an existing ID instead
   of appending a new one (#3846)
 o bonne: fix inverse map projection computations when lat_1 < 0 (#3849)
 o WKT1 ESRI import/export: fix GCS name for EPSG:8353 S-JTSK_[JTSK03]_Krovak_East_North (#3851)
More information about the PROJ mailing list
