[PROJ] PROJ 9.3.0 & PROJ-data 1.15
Javier Jimenez Shaw j1 at jimenezshaw.com
Fri Sep 1 11:16:09 PDT 2023
Thank you very much for the release!
Just one thing for the release process: The documentation in proj.org is
still referring to 9.2. In fact 9.3 does not exist yet.
(I know, this is the first time we change the minor version having read the
docs).
Cheers,
Javier.
On Fri, 1 Sept 2023, 14:10 Kristian Evers via PROJ, <proj at lists.osgeo.org>
wrote:
> I'm happy to announce the release of PROJ 9.3.0 and PROJ-data 1.15!
> The PROJ release includes a number of updates to the both functionality and
> the database contents, as well as a number of bug fixes. See the release
> notes
> below.
> The PROJ-data release includes the following updates:
> - Argentinian GEOIDE-Ar16 geoid model
> - Polish PL-geoid2021 geoid model
> - Canadian HT2_1997, HT2_1997_CGG2013a, HT2_2002v70 and
> HT2_2002v70_CGG2013a vertical grids
> Download the archives here:
> http://download.osgeo.org/proj/proj-9.3.0.tar.gz
> http://download.osgeo.org/proj/proj-9.3.0.zip
> http://download.osgeo.org/proj/proj-data-1.15.tar.gz
> http://download.osgeo.org/proj/proj-data-1.15.zip
> /Kristian
> 9.3.0 Release Notes
>  Updates
>  o Add C++ API to transform coordinate (#3705)
>  o CMake: add PROJ_DB_CACHE_DIR (#3711)
>  o Implement EPSG:1026 Mercator (Spherical) method (#3741)
>  o CMake: remove useless cross-compiling related checks (#3747)
>  o Add mapping of Equidistant Conic to new EPSG:1119 method (#3812)
>  o Implement proposal001 from Planetary DWG from OGC (#3816)
>  o Add option in proj CLI to use a CRS (#3825)
>  o proj_factors(): make it work with projected CRS with non-metre unit
> and/or
>    northing/easting axis order (#3826)
>  o PROJ_DEBUG: make ON an alias of 2, and OFF of 1 (#3835)
>  o Database: update to EPSG 10.094 (#3847)
>  Bug fixes
>  o GeographicBoundingBox::intersection(): avoid infinite recursion and
> stack
>    overflow on invalid bounding boxes (#3748)
>  o Various fixes related to concatenated operations (#3820)
>  o Projected CRS identification: fix crash when the base CRS is a
>    non-geographic geodetic CRS (#3830)
>  o Avoid C++ exceptions to be thrown (and caught) when parsing strings
>    like '+proj=longlat +datum=WGS84 +type=crs' (#3834)
>  o BUG: Handle prefix whitespace when guessing WKT dialiect (#3841)
>  o proj_alter_id(): make it replace an existing ID instead
>    of appending a new one (#3846)
>  o bonne: fix inverse map projection computations when lat_1 < 0 (#3849)
>  o WKT1 ESRI import/export: fix GCS name for EPSG:8353
> S-JTSK_[JTSK03]_Krovak_East_North (#3851)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230901/28dcdfa8/attachment.htm>
More information about the PROJ mailing list
