[PROJ] PROJ files path
Rhea rhea.moubarak at gmail.com
Tue Sep 5 03:39:25 PDT 2023
hello,
is there a way to verify the correct path of the PROJ files? i looked it up everywhere and i only found that its in /usr/share/proj/, is it true for all proj versions?
Thank you,
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230905/3146a26a/attachment.htm>
More information about the PROJ mailing list
