[PROJ] PROJ files path
Javier Jimenez Shaw j1 at jimenezshaw.com
Tue Sep 5 05:15:27 PDT 2023
There are several ways to configure it
https://proj.org/en/9.3/resource_files.html#where-are-proj-resource-files-looked-for
On Tue, 5 Sept 2023 at 12:39, Rhea <rhea.moubarak at gmail.com> wrote:
> hello,
> is there a way to verify the correct path of the PROJ files? i looked it
> up everywhere and i only found that its in /usr/share/proj/, is it true for
> all proj versions?
> Thank you,
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230905/1c0fb5bd/attachment.htm>
More information about the PROJ mailing list
