[PROJ] Installing the projection package
Even Rouault even.rouault at spatialys.com
Fri Sep 15 06:39:20 PDT 2023
Le 15/09/2023 à 15:34, Rhea a écrit :
> Hello,
> We noticed that we are missing the file: https://github.com/OSGeo/proj-datumgrid/blob/master/ntf_r93.gsb in the proj folder.
Cf https://proj.org/en/9.3/resource_files.html#transformation-grids and
https://github.com/OSGeo/PROJ-data/releases
> For installing the file if there is a projection package ? Before on proj 4, we had a projection package with this file: dnf install *proj* does this still exist for proj 8?
just tested on fedora:rawhide:
dnf install proj-data proj-data-fr
or for everyting:
dnf install proj-data*
> thank you for your help.
> regards,
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
More information about the PROJ mailing list
