[PROJ] Installing the projection package
Jürgen E. Fischer jef at norbit.de
Fri Sep 15 06:45:57 PDT 2023
Hi Rhea,
On Fri, 15. Sep 2023 at 15:34:16 +0200, Rhea wrote:
> We noticed that we are missing the file: https://github.com/OSGeo/proj-datumgrid/blob/master/ntf_r93.gsb in the proj folder.
> For installing the file if there is a projection package ? Before on proj 4, we had a projection package with this file: dnf install *proj* does this still exist for proj 8?
proj-datumgrid it archived: "NOTE: This repository is only to be used with PROJ < 7. For PROJ 7 or later, use the PROJ-data repository."
ie. https://github.com/OSGeo/PROJ-data
See also https://proj.org/en/9.3/download.html
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230915/ee9cb1c2/attachment.sig>
More information about the PROJ mailing list
